It is currently Mon Nov 02, 2026 2:40 am
Post Posted: Sat Jul 19, 2008 10:54 pm
OK posting this here just for peoples info as I know this is a popular pump for sierra EFI conversions
here is a pic of the pump as removed and by itself, to me it looks pretty similar to an ordinary jap car intank pump and all teh 500hp skyline pumps on ebay, so hopefully I can find something tomorrow at my local autocheap that I can make fit
or I can go get one of them fancy ones and justify it by fitting NAWWWZZZZZ :goodjob:
Post Posted: Sun Jul 20, 2008 12:11 am
Certainly does look like every Jap in tank pump. Can you just buy the pump by itself with out buying the whole lot?
Post Posted: Sun Jul 20, 2008 12:16 am
so far repco dont list a pump for it so will have to hunt around tomorrow to see who has what on the shelf
no idea on genuine, I dont earn enough to even ask
it did come good after smacking it with a shifter but I'm not game enough to refit it :)
Post Posted: Sun Jul 20, 2008 12:19 am
I know with the Ford in-tank pumps you can just buy a replacement pump. I think they are Bosch?
Post Posted: Sun Jul 20, 2008 1:00 am
yeah you can buy a few aftermarket replacement pumps, shouldnt be hard to get one close enough to a match
Post Posted: Sun Jul 20, 2008 2:13 am
hay royce, today the vitara shat itself!
for the last week it has been really laggy with acceleration, but today i turned it over after having a 30min drive and it started and then ideled really ruff and then to the stage where it stalled. i could start it again but it ran really ruf and stalled, even if i had my foot to the floor on the accelerator it didnt make a differnce, im not sure if it is my fuel pump or just a blocked filter, i will be replacing the filter tommorow.
What are your thoughts, do you think it could be the fuel pump?
if so how much roughly are they going for and are they hard to install.
Post Posted: Sun Jul 20, 2008 5:13 am
i got a vit pump here in logan. im not sure of condition.
i think you will be best to just go to atuobarn or the like and match up one
Post Posted: Sun Jul 20, 2008 1:03 pm
petroject list a replacement pump for the vit, same pump is used in V6 mitsubishis and 6cyl Subarus so I would assume it can supply enough for anything you might want to do to a 1.6
will see how much tomorrow
Post Posted: Mon Jul 21, 2008 6:49 pm
well new pump has arrived, $121.18 later
its a Bosch pump, lited as common Japanese car 38mm
Bosch number is 0580453477 if anyone knows of a list to figure its specs out, googling brings up lots of strange cars
Vehicle: Zookless
Post Posted: Mon Jun 28, 2010 11:21 am
Good thread Royce, just what I've been looking for :)
I've picked up a coily tank for my EFI conversion. Obviously I plan on using a Vit pump.
My questions is, can I use the coily pick-up? Or do I have to get one from a Vit tank?
Here's the coily pick-up
The pump could just hang off the discharge line easy enough. But can I get fuel resistant grommets for the wires to the pump? I'm a bit worried about fuel leaking out...
Post Posted: Mon Jun 28, 2010 11:49 am
Have a wrecker scrounge. I reckon almost any EFI suzuki will have the same pickup bolt pattern and sort out the grommets, lines etc for you. (PS they don't use grommets - they use insulated pass-throughs that are fuel proof.)
Vehicle: Zookless
Post Posted: Mon Jun 28, 2010 11:56 am
Well there you go, I thought grommets would be a bit dodgy...
Thanks Steve :D
Post Posted: Tue Jun 29, 2010 4:20 am
hey royce.
has this been fitted yet? does it work?
Post Posted: Tue Jun 29, 2010 4:51 am
the pump? its been supplying explosive liquid since about July 23 2008 :)
only drama I had with it was refitting it the assembly was a bit long and bottomed out on the tank so I lifted it a bit while balancing the tank half unbolted so have no idea where empty really is anymore :)
Vehicle: Zookless
Post Posted: Tue Jun 29, 2010 5:52 am
I found a pickup and pump from a 2000 Baleno.
The flange is exactly the same, so it bolts straight in :)
Unfortunately the Baleno tank being a little shallower than the Coily Tank, means that the pump will sit about 100mm off the bottom. This was easily fixed by extending the discharge line with pipe and the pump wiring with fuel resistant wires.
Post Posted: Tue Sep 27, 2011 10:10 am
ok well my fuel pump seemed to have died today, thought i might re dig this thread instead of making a new one.
rang suzistore and they have 2 fuel pumps a 38mm ($199) and a 51mm ($245) is it worth going to 51mm or just stick to the 38mm? or will the 51mm pump be completely different and worth the upgrade??
cheers
Post Posted: Tue Sep 27, 2011 10:20 am
I would go the 38mm, because even if the 51mm can deliver more fuel you're never going to need it unless you whack a turbo on. Even then...
HAY ROYCE!!!! did your tank have a cup or something like that on the bottom of the tank to keep the fuel around the pickup in corners???
I retrofitted my stock leafy tank with a RX7 pump and pickup that looks pretty much like yours. However I find that if i'm at 1/4 tank or below, hard left hand corners induce low fuel pressure backfires :lol:
Post Posted: Tue Sep 27, 2011 10:24 am
I know that coily tanks have a swirl pot in the bottom, so I would imagine that the EFI vits do aswell.
Post Posted: Tue Sep 27, 2011 10:26 am
cheers
...you could use a hairdressers water squirter and it would probably inject enough fuel in the lines for a 1.6...
and if your paying that much for a fuel pump your getting Ripped. 58 Dollars for mine from Nepean Auto Spares. like with royces, mine was suited for a V6 Paj, a Subaru Lib's and a few other cars.
Stocker
Vehicle: LWB Sierra & XL7
Post Posted: Tue Sep 27, 2011 10:50 am
I bought mine of ebay and fits and works just fine. The one I bought for the corolla turned out to be pretty much the same pump, I had to muck around with the wiring plug but nothing a little solder and heat shrink didn't fix. I have also noticed and Nissan and Mitsu pumps are the same.
Both the pumps I bought off evilbay were about $60.
'92 Vitara & Camper trailer
Post Posted: Tue Sep 27, 2011 11:16 am
ok thanks fellas, i havnt seen where else i can get them from. thought i might try them and thats what they said.
not sure where my mechanic is going to get it from, will soon find out.
thanks
Vehicle: WR250F/Jeep XJ
Post Posted: Tue Sep 27, 2011 11:40 am
Walbro pumps also bolt in. Check my build thread...but be warned!! they crap out VERY quick if run dry! It's a different type of pump to the Vitara one in design the vitara pump is a lot more durable and have been running my 4age 20v reliably for 18 months.
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Tue Sep 27, 2011 8:35 pm
Yeah its got a little ring in the bottom to keep fuel in around the pickup, its why my tyres are wearing on the outside edge so much :)
Vehicle: 1995 swb vitara
Post Posted: Tue Sep 27, 2011 11:17 pm
I have used a . Vp commodore 6cyl efi pump with no issues
There is some wiring that requires changing : ie the power conector is different - use the filter that comes with the commo pump
And hoseclamp the shabangabang to the pickup
I used it as a backup until a replacement turned up
From eBay - $$ price from there was about $40
Hope this helps
Post Posted: Wed Sep 28, 2011 7:10 am
Hope this helps
Beat me to it............
Post Posted: Wed Sep 28, 2011 7:45 am
steak_knife wrote:
SQUIRREL wrote:
I have used a . [b]Vp commodore 6cyl efi [/b]pump with no issues
Hope this helps
...theres your problem
:lol:
Stocker
Users browsing this forum: No registered users and 78 guests
