Joined: Fri Oct 23, 2009 10:30 pm Posts: 257 Location: Brisbane North
Vehicle: 02 GV
Posted: Sun Sep 18, 2011 2:39 am
just after some advice.
looking at getting an aldi winch. I was thinking as the GV is so light I could get away with mounting the winch in the alloy bar. just beef up the mounts.
the bull bar is 8mm alloy.
the othe option is to buy a universal winch cradle and try that way.
He also used a couple lengths of flat steel, about 4mm thick i think, later on, bolted from the bottom of the winch to the front cross member to give some extra strength
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
Posted: Sun Sep 18, 2011 9:39 am
What they said. Build a winch cradle that bolts to the ends of the chassis and also bolts to K frame (front cross member) Once that is secure then mount the alloy bar onto the winch. Nice and strong and looks like its ment to be.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 40 guests
