It is currently Tue Oct 27, 2026 5:08 pm
Post Posted: Mon Sep 05, 2011 3:49 am
I have a lwb 1.6 vitara and I need to upgrade the brakes
I have sloted and vented front rotors
Is there any master and boosters that have a higher pressure that will bolt in with out to much trouble
Will rear disk help much
I'm looking to see if I can get a gvm upgrade so i want the most stopping power that I can get
Post Posted: Mon Sep 05, 2011 3:59 am
Fit 2.0L rotors and calipers. You'll need 16 or 17" wheels though.
Post Posted: Mon Sep 05, 2011 4:01 am
Do you have the same Isuzu rodeo's and Isuzu trooper's we have, over there?
If you do , let me know and I will find the thread that documents the M/C booster swap, it is bolt on and helps heaps.
Vehicle: LJ50V, SJ70
Post Posted: Mon Sep 05, 2011 4:06 am
Yes, we do, but they're called Holden Rodeos (or the new Colorado) or Holden Jackaroos. Of course, they are also RHD, so there may be a difference with the size/layot of the Booster and Master Cylinder.
Post Posted: Mon Sep 05, 2011 4:10 am
Look into heir booster and M/C Weed over on Zuwharrie bolted one right in place he did a nice write up on it.. I believe the lines/fittings are metric as well.
Vehicle: LWB Sierra & XL7
Post Posted: Mon Sep 05, 2011 4:28 am
I've got standard front with BenT's Rear disc kit. It's gooood. Made a massive difference. The only downside is that I didn't get slotted rotors, which I kinda wish I got now.
For the price of new drums and shoes, you may as well get the rear disc conversion.
'92 Vitara & Camper trailer
Post Posted: Mon Sep 05, 2011 4:30 am
I want to see how much the mc and booster do before I go to bigger front brakes as it would mean buying 8 new rims and tires
Post Posted: Mon Sep 05, 2011 11:16 pm
Are the gv brakes bolt up except the needong bigger rims?
Post Posted: Mon Sep 05, 2011 11:49 pm
doesnt matter how much you change what creates the pressure into teh pistons, a given caliper / rotor combo will only provide so much braking effort, I dont think there is any requirement to be able to provide a given amount of braking for a certain amount of pedal pressure
Post Posted: Tue Sep 06, 2011 12:33 am
So is it a bolt in or are the master cylinders different?
Post Posted: Tue Sep 06, 2011 6:11 am
One of my mates has just done the Rear disc brake combo upgrade, omfg... its like having a set of twin spot's compared to mine :D
Stocker
Post Posted: Tue Sep 06, 2011 6:14 am
Why do people think discs offer more outright braking power?
Post Posted: Tue Sep 06, 2011 6:22 am
we did a test. side by side, same time ( i cheated a little ) and he still pulled up before me... ...Question not a statement, but aren't Disc brakes more efficient at dissipating heat, therefore providing better stopping power ( like i said royce question not a statement, thats just what i was led to believe and whether that was the blind leading the blind i don't know)
Stocker
Post Posted: Tue Sep 06, 2011 6:29 am
Discs are better at
being simple to build and install
being virtually maintenece free
working when wet
dissapating heat
So all that makes them more reliable in a passenger car, the heat thing is more of an advantage during repated stops rather than single outright
They have a lot less friction area than drums so need to squeeze a lot harder than drums for the same force, when you jsut bolt discs on the back you still have the same input pressure
Anyone who has driven 4 wheel drum brake cars a lot will tell you they pull up well, when they are sdjusted properly and are cool :), which is pretty easy in the back of a Suzuki
Post Posted: Tue Sep 06, 2011 6:33 am
i see... well i do have well adjusted drum brakes (till it locks up and 3 clicks back ) , new shoes, and i've got brand new cylinders... and mine doesn't pull up as well as the other LWB with disc's? Please explain??? i really wanna know why that is.
Stocker
Post Posted: Tue Sep 06, 2011 6:38 am
most of the braking goes on in the front, same pads and rotors? same tyres? same suspension? same tyre pressure? same shock wear?
Post Posted: Tue Sep 06, 2011 6:44 am
well i have all brand new Dobinson Shocks same size tyres, different type.
He has same suspension except still calmini struts. same BL, Same tyre pressure.
I have RDA Slotted Rotors and Bendix 4wd Pads, he has RDA Solid Rotors and Bendix 4wd Pads...
Stocker
Post Posted: Tue Sep 06, 2011 7:08 am
Spring lift can alter how the rear brake bias sensor works.
Adjusting that, or compensating for the height increase,
can make a huge difference to brake performance
Post Posted: Thu Sep 08, 2011 8:48 am
My 04 GV is running slotted rotors and braided brake lines and the difference is awesome.......cost me a fortune but well worth it :)
Post Posted: Fri Sep 09, 2011 8:06 am
you can still get away with 15" rims with a very slight bit of grindage, im running 15X7 sunnies on mine with 0 offset
Vehicle: 94 Vitara LWB
Post Posted: Fri Sep 09, 2011 8:54 pm
Slotted discs would be a pain to clean if off roading all the time especially if you like mud etc. . Wouldn't they also in those conditions collect stones and gravel in the slotts and wear grooves in you pads . Be good to know from someone whose tried them out.
Users browsing this forum: No registered users and 232 guests
