It is currently Mon Sep 21, 2026 3:51 pm
Post Posted: Tue Sep 06, 2011 12:18 am
Hi Guys
I bought some 15X7 rims and 31" tyres from jas at sunshine coast sierra wreckers, sadly they scrape at full lock (both directions) on my newly installed lifted springs!!! (91 sierra SJ70 swb)
Jas has suggested installing longer bolts in the swivel hubs to decrease steering lock.
I have used the search function but can't find anything about it on the forum. Can anyone point me in the direction of a how to? or offer advice?
Barring this ill probably just have to buy some 235/75s to stop the problem but id rather not buy more tyres if i dont have to, plus the 31s look great!!!
Cheers all
Post Posted: Tue Sep 06, 2011 1:10 am
Just turn the steering wheel less :wink:
Post Posted: Tue Sep 06, 2011 1:11 am
thanks royce, ive been utilising that theory for the last day and a half!!! makes getting in and out of the driveway at home hard!!!
Post Posted: Tue Sep 06, 2011 1:20 am
longer bolts are only going to do the same thing as turning the wheel less far.
Post Posted: Tue Sep 06, 2011 1:24 am
but will they physically stop the wheels from turning far enough to hit?
Post Posted: Tue Sep 06, 2011 1:27 am
thats the idea yeah.
i just welded a nut onto the top of the steering stop bolt.
Post Posted: Tue Sep 06, 2011 1:30 am
yes but you will also have less steering
Just let em hit :)
Post Posted: Tue Sep 06, 2011 1:38 am
lol fair enough, i was actually worried about ripping the tyres to bits, but i guess if im gonna replace them i may as well get a few months out of them first!
cheers guys
Post Posted: Tue Sep 06, 2011 8:00 am
cheers guys
I have Suzuki rolling chassis here where a tyre has slowly worn away a good part of the leaf spring pack! 8O .
Clearance Hole Technology :P
Vehicle: LJ50V, SJ70
Post Posted: Tue Sep 06, 2011 12:48 pm
lukemc wrote:
Hi Guys
Cheers all
Try http://www.auszookers.com/index.php?nam ... pic&t=8377
Post Posted: Tue Sep 06, 2011 12:51 pm
my offset helps to clear the springs.
15x8 rim with -25 offset.
Post Posted: Tue Sep 06, 2011 9:29 pm
Thanks 303zuke excellent help
Yeah dan obviously the offset on these isn't right for mine, lesson learnt by me to check b4 you buy!
Post Posted: Tue Sep 06, 2011 9:56 pm
Highway-Star wrote:
cheers guys
now thems some good ruber
Vehicle: '94 suzuki maruti
Post Posted: Tue Sep 06, 2011 10:28 pm
15x7 -13 fits too, i have more than a cm of space at full lock between tyre and spring
Post Posted: Tue Sep 06, 2011 10:37 pm
Wheel spacers?
They come in varying sizes.
PM Dank if you want to go that way.
Post Posted: Thu Sep 08, 2011 5:26 am
i run 15x7 neg 12 30x9.5 best combo ive had so far
Post Posted: Fri Sep 09, 2011 11:30 am
i went down to bob jane today and got them to fit up 2 235/75/15s to test them
They still hit b4 getting to full lock on the springs..............
ill measure the offset tomorrow , but they rang king wheels while i was there and they confirmed the rims i have "should" be able to run 31"s without hitting suspension.........
is it at all possible i have a NT? its a 1991 model with metal flares
Post Posted: Tue Nov 01, 2011 12:58 am
finally got around to measuring the offset on the rims i have and as far as i can tell its negative 13!
im gonna try this bolt fix soon
Slow process i know! and sadly the misses is hitting me up to sell the suzy as we have hit some hard times cash wise.....
i did offer to sell her cats instead but i don't think they would fetch much!!!
Post Posted: Tue Nov 01, 2011 5:50 am
my 235,s just scrapped on full lock.stuck a washer behind the nut on the hub seal ..problem solved..probably lost about 1/8 of a turn on the steering wheel on full lock...washer is as good as a $10 bolt
Vehicle: 85 Suzuki Sierra
Post Posted: Tue Nov 01, 2011 12:20 pm
Its odd your having so much trouble with not amazingly huge wheels in a WT. Putting washers on isn't going to help you get in the driveway any easier :P, more offset rims would surely help you out but that do cost money :(.
My 31x10.5 on 15.8" ~-20/25 rims rubbed awesomely on NT difs for a few years but I just didn't turn in as much as I could. I had no idea suzuki made longer bolts to fix this problem for a few years until i read about it in this thread haha, my 85 NT difs didn't fyi.
I swapped to wt difs to fix this problem and now I have inches of room between the tyres and the springs. :/
Orange LWB Sierra
Post Posted: Tue Nov 01, 2011 11:06 pm
Just out of curiousity, post a pic up showing the spring mounts on the chassis and front diff will you?
Post Posted: Tue Nov 01, 2011 11:11 pm
I found some pics in this thread:
http://auszookers.com/index.php?name=Fo ... ic&t=25668
Not sure why i didn't do that last night. It looks like a WT.
I also just realised i have nt spring spacing on wt difs, so ignore me :P.
But pics of the tyre on full lock could be handy :)
Orange LWB Sierra
Post Posted: Tue Nov 01, 2011 11:47 pm
No worries here are the pics.......
http://imageshack.us/photo/my-images/847/img0020gx.jpg/
http://imageshack.us/photo/my-images/830/img0021kx.jpg/
Post Posted: Tue Nov 01, 2011 11:50 pm
Are the tyres rubbing on those massive U shaped clamps?
Orange LWB Sierra
Post Posted: Tue Nov 01, 2011 11:51 pm
nope they rub at the rear on the actual suspension leaves
Post Posted: Wed Nov 02, 2011 11:23 pm
did the pictures show up anything odd to you want33s?
Post Posted: Thu Nov 03, 2011 12:21 am
Your suz is a WT
Either remove the bolts or turn them around. Threads are not nice to tyres!! I dont understand why they are designed that way. Right on the corner edges of the tyres when you turn.... Shit design.
I had other springs, My spring clamps were different, But i bent them open for more movement- Just the same as you removing the bolts completely.
I also had a wt, 33x12.5s with -28's. I rubbed, But on the actual leafs, Not clamps.
Post Posted: Thu Nov 03, 2011 12:55 am
Nah mate all looks good to me.. Yours is definitely a WT.
I would be removing the bolts from the clamps for better flex.
Got me stumped why you are having clearance dramas though....
Users browsing this forum: No registered users and 152 guests
