It is currently Sat Sep 26, 2026 12:51 pm
Post Posted: Mon Jul 21, 2008 5:23 pm
Just trying to find out info in regards to a list i found a while ago in regards to doing this conversion. The thing is i cant find it. So ive created a new one.
I own a 1991 W/T Suzuki Sierra 1.3L JX.
Ive purchased a MK1 GTI motor and loom and ECU from RobboK off this forum as well as a fuel VL Fuel pump.
Ive created a list as follows:
- Sierra Clutch/Flywheel and pressure plate.
- G13b MK1 Suzuki GTI Swift motor
- G13B MK1 Wiring Loom
- Electric Fan OR Use the Sierra Water Pump and orginal Fan.
- GTI Exhaust Flange and custom extractors/exhaust.
- MK1 ECU
- Mazda 1989 (not 1990 and above) 323 GTX 1.6L Turbo Distributor Cap AND rotor button. (Is this all i Need???? If not what else?)
- VL Fuel Pump (Will i need a Surge tank and/or small inline fuel pressure pump??? As in one high and on low pressure fuel pump?)
- Use Sierra Sump onto bottom of G13B (As Swift Sump hits??? Correct??)
- Run a Return Line line from the fuel rail to the tank. (Use the original Feed line???)
- 4L of (5W30 to 10W40) Oil (Im guesing it will use approximately 3.5L of oil) and corresponding oil Filter.
- High Pressure Fuel Filter
- EFI fuel hoses (replacing all original rubber lines) (Or use the Sierra???)
- Run a Radiator hose to the thermostat? (Or is this for only later versions MK2/3???)
- 5-7L of Coolant
- New Spark Plugs
- Mitsubishi Astron Thermostata housing (P/N W022A)
- New timing belt so not to replace it later and pulling the motor back out.
- Longer Starter motor and Alternator Lead Lengths??? (is this true or are they on the same side as the orignal Sierra Carby motor????)
Thats all ive got info from doing hours of research,
What other bits and pieces do i need? I really just want it to go smoothly and to complete it in about a couple of hours. Im a mechanic by trade so should be able to work most of it out myself. Plus the wiring should be quite easily also.
I know its a relatively easy conversion but ive got a feeling im going to forget something half way through that i should of bought.
I know i have asked a lot of questions but if someone who has done this conversion please send me an SMS on 04 10 756 872 and ill call you about it. It would just help if i could actually call someone regarding the install.
Any help would be muchly appreciated!
Regards,
Stewy (04 10 756 872) Newcastle
P.S the G13BA (or whatever is in my car) tested 160psi on the first cylinder and pretty much 110psi on the rest)... bad joo-joo seeing standard Compression should see 200psi in each cylinder :(
Post Posted: Mon Jul 21, 2008 8:47 pm
Hey Stewy,
I can't help you with everything, but this is what I know...
Have you got a wiring diagram? You will want a Mk.1 GTi diagram and WT Sierra diagram. The Sierra one you should be able to download from the downloads section on this site. Try redlingti.com for a GTi diagram
I'd use a stock fan. Easier and less shit to go wrong. Put an ad in the wanted section if you need one.
You don't NEED a surge tank, but I think it's definitly the best way to go. Those inline fuel pumps like a constant supply of fuel on the suction side.
You should already have a fuel supply line and a return line. I have used the standard lines on a couple of conversions and they have worked fine.
Yes. I used a Valvoline VF6 inline filter, and re-used the old coil mount as a bracket :D
It wouldn't hurt to replace the lines., since they're nearly 20 years old.
HTH.
Damo.
Post Posted: Mon Jul 21, 2008 10:19 pm
youll need to replace the fuel hose with efi rated stuff
Users browsing this forum: BlueSuzy and 250 guests
