It is currently Sun Oct 25, 2026 3:39 am
Post Posted: Thu Sep 08, 2011 6:08 am
So I wanna see what people are running, largest on unmodified body etc, largest on huge lift etc,
I'm thinking of trying to fit some pretty big tires to a stock xl7 to try get some ground clearence on some all terrains mainly for dirt track use to camping grounds and some seen ruts etc.
I think I will just do some major bumper trimming and try run some 245 75 r16 any one doing anything similar? Like stated in my other thread I'll most likely do a proper 40mm spring lift later but I really want the tyres now to use, I'm due for tyres now.
Thoughts and pics of what your running? I'd really like to make his the one any only definitive tyre size thread for GV
Ryan.
Post Posted: Thu Sep 08, 2011 6:26 am
Ryan.
225/75R16 0r 245/70R16 will fit as is without any lift. They may rub a little but will fit.
To fit the245/75R16 04 255/70R16 you have to trim quite a bit of plastic from inside the wheel arches. Gearing will suck with this size tyre. You neew do swap diff ratios but there are none available for the XL7. Rear diff is different to GV or so im led to believe.
Post Posted: Thu Sep 08, 2011 6:38 am
Hmm I hate my ratios anyway, I much prefer the higher gearing for highway Ks as I'm either traveling 100 highway Ks to work or going offroad, rarely city driving
Is it it going to be a big change? Would it be a strain on much or just a fuel consumtion?
Post Posted: Thu Sep 08, 2011 6:39 am
What ratio is the xl7 diff because u can get 5.12 for xl7
The rear is bigger then a gv
Post Posted: Thu Sep 08, 2011 6:43 am
Crawl ratio will be crap. Will end up riding the clutch alot. If its an Auto it will slowly over heat the auto due to the extra load it will put on it. Fitting a trans cooler will help.
Post Posted: Thu Sep 08, 2011 6:45 am
Manual, the work I do is never crawl, I've used low range 2nd once to get out of some mud on my stock tires, though with better tyres I think I will find myself venturing further into places. I'll get my book and throw up the xl7 ratios
Post Posted: Thu Sep 08, 2011 6:51 am
Owners manual has every specification but ratios :(
Post Posted: Thu Sep 08, 2011 6:58 am
245/75R16 are about 12.5% bigger than a stock 235/60R16 so where you used to be in low 2nd you will be having to use 1st.
Post Posted: Thu Sep 08, 2011 7:08 am
Sounds good to me, just a matter of making them fit stock bodied and springs for now :s
Post Posted: Thu Sep 08, 2011 7:09 am
4 inch grinder and a 1mm disc will make short work of the plastic guards.
Post Posted: Thu Sep 08, 2011 7:22 am
Yeah I've trimmed many a gaurds on my go fast cars before :) I might even make up some thin alloy replacements out of the way if there are certain things that should be protected? I'm just reading your thread now B4T
Post Posted: Thu Sep 08, 2011 7:32 am
There is a build on zukiworld that runs 37 on his xl7 so anything is possible with enough cutting
Post Posted: Thu Sep 08, 2011 7:54 am
And also a lot of lift I'm guessing haha I might just go 245 70 for now
Vehicle: 2001 XL7
Post Posted: Thu Sep 08, 2011 8:51 am
Xl7s have bigger wheel arches than GVs but not by much, 235/70/16 is a good fit with no lift.
Post Posted: Thu Sep 08, 2011 9:08 am
I was told that 235 70 is actually shorter then 225 75
Post Posted: Thu Sep 08, 2011 11:56 am
Correct....all of 6-7mm shorter, thats all
My Grand Vitara
Vehicle: 2001 XL7
Post Posted: Thu Sep 08, 2011 12:00 pm
Look at them side by side on a GV and it still looks bigger than a 225.
Post Posted: Thu Sep 08, 2011 12:04 pm
Also depends on brand of tyre, and type of tread as well
My Grand Vitara
Post Posted: Thu Sep 08, 2011 12:23 pm
also depends on gv model also
Users browsing this forum: Google [Bot] and 94 guests
