It is currently Mon Oct 26, 2026 6:52 pm
Post Posted: Thu Sep 08, 2011 11:52 pm
hey, ive got a h20a vitara and i just swapped the front diff housing for steel, and now im after some 5.12 diff gears, but i realised the diff.centre from.the gv that i got the steel house from are 8/43 which is 5.3 so is there a 5.3 centre i can get for the rear? or do i still need 5.12s for both? i just thought itd be better seeing as id already have the front sorted out. thanks
Post Posted: Fri Sep 09, 2011 12:03 am
Years....2 or 4 door...Engine type...Transmission...Axle ratio
89 2 1.3L carb. 5 speed man. 5.625
89-95 2 1.6L TBI 5 speed man. 5.125
89-95 2 1.6L TBI 3 speed auto 4.625
91 4 1.6L TBI 5 speed man. 5.375 4dr. 2door is 5.125
91 4 1.6L TBI 3 speed auto 4.625 2 or 4dr.
91 samurai, 5sp 3.727 (refr)
92-98 4 1.6L MPFI 5 speed man. 5.125
92-98 4 1.6L MPFI 4 speed auto 5.125
94-98 2 1.6L MPFI 5 speed man. 5.125
94-98 2 1.6L MPFI 3 speed auto 4.30
94-98 2 1.6L MPFI 4 speed auto 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
96-98 4 door 1.8l 16V DOHC MPFI manual or auto 5.125
4.30 gears have a 10/43 tooth count
4.625 gears have an 8/37 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
Post Posted: Fri Sep 09, 2011 12:32 am
WTF a 5.3:1 GV steel diff, that's news to me. are you sure it wasn't 10/43?
can you take a pick of the GV steel housing?
so its out of a 4 door 1.6 91model. what does tbi mean? so the 5.3 is pretty rare im.guessing? thanks
Post Posted: Fri Sep 09, 2011 12:46 am
recount em, most steel diffs are 10/43
for them to be 8/43 somebody would of had to change them in which case youll find what you need in the rear of the same car
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Fri Sep 09, 2011 12:50 am
TBI = Throttle Body Injection also know as single point injection. Not multi point injection.
Post Posted: Fri Sep 09, 2011 12:57 am
no im not sure its 8/43 i only counted the.crown wheel then searched 43 teeth diff and foind this 5.3 thing i disnt.see anything about 10/43 so i didnt check the pinion. but it looked like the diff had been apart before so it could have got changed.
Post Posted: Fri Sep 09, 2011 1:07 am
so you counted 1 gear of 2 to get a ratio, took that number and ran with the nicest result you got back?
I have a feeling you will face a let down sometime shortly :wink:
i put my left nut on it being 4.3:1
Post Posted: Fri Sep 09, 2011 1:38 am
i hope i dont win that bet
Post Posted: Fri Sep 09, 2011 2:02 am
you can't back out now.... :lol:
Post Posted: Fri Sep 09, 2011 6:20 am
luckily for your scrotum the pinion has got 10 teeth
Post Posted: Fri Sep 09, 2011 6:42 am
Armsup
Dearest Jonno_Raping Bucket, you ungreatful fucks... see I am helpful. :thefinger:
Post Posted: Fri Sep 09, 2011 7:58 am
im grateful thanks man :)
Post Posted: Fri Sep 09, 2011 8:09 am
once you swap the 5.12's into the GV steel diff, the 4.3:1 R&P can be advertised for sale to recoup some of the $$$'s as the sierra guys use them to regear their diffs.
Users browsing this forum: No registered users and 351 guests
