Page 1 of 1
[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Tue Jul 22, 2008 1:15 am |
the beast has developed a missfire and loss of power when driving. started playing up on way out last sunday. It would just suddenly cut out and pop and fart untill you pulled over . After a few minutes looking for any loose wires or bad conections it would start up and idle as normal.
Did this all day. The higher the constant revs were the quicker it would play up again. On the way home it got that bad it was backfiring and blowing flames out exhaust. as a last ditch effort to get home we had to hot wire the coil. this helped but ya could still feel it trying stutter.
Now since getting home i have replaced the dizzy, coil, tried different leads, checked and cleaned the plugs, and even did a compression test but still it cuts out.
Any ideas of what to check or replace next.
royce
 Posted: Tue Jul 22, 2008 1:18 am |
if wiring power to the coil fixed it its probablya s tuffed ignition switch, any other probs are unrelated and probably stuffed plugs
are you changing all this and still hot wiring the coil power?
without the hotwiring I would say the module was stuffed or the pickup in the dissy is loose
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Tue Jul 22, 2008 1:23 am |
B4T, you've got a 16v haven't you? One with the external coil? I'm guessed ignition pickup but hotwiring the coil shouldn't have made any difference if it was.
_________________ SJ50.4.LYF
Built4thrashing
 Posted: Tue Jul 22, 2008 1:42 am |
sorry i should have said.
Its still the 1.3. I replaced the dizzy and coil and it still happends.
Hot wiring didnt fix it but it helped keep it goin to get home from coldstream.
_________________ B4T
fat_tony
Joined: Sun Jun 29, 2008 11:30 pm Posts: 61 Location: penrith nsw
 Posted: Thu Jul 24, 2008 3:11 pm |
hey mine does this too, the weird thing is, it only does it when i have less than a quarter tank of fuel, when i hit a bump, its cold and/ or raining, some time it doesnt have to be cold or wet..... weird, have no idea have checked timing, connections etc
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 124 guests
