It is currently Mon Jun 22, 2026 9:32 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
Post Posted: Sat Sep 10, 2011 10:42 pm
Hey guys, been rackin my brains for the last few days, kermys been spitting 2ft flames from the exhaust and as cool as it seems I don't want to BBQ cars behind me, never used to do it at all until a day or 2 ago,
Here's a bit of dogey iPhone video
http://www.youtube.com/watch?v=bugIlY5ayek
Any ideas
I'm running a 4age 20v with a bosh inline h/p fuel pump
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Sat Sep 10, 2011 10:44 pm
are you for real? that is cooler then the coolest thing ever. if ya find out what causes
it can ya post up a how to?
baaahhhhaaaa! are you running per ethanol?
Take it to the tracks...lol
255 characters
Post Posted: Sat Sep 10, 2011 10:45 pm
is it misfiring? that could cause a buildup of fuel in the exhaust.
it looks gangsta anyway
Post Posted: Sat Sep 10, 2011 10:46 pm
vid wont work 4 me :(
255 characters
Vehicle: LWB Sierra & XL7
you need to stay away from open flames.
Post Posted: Sat Sep 10, 2011 10:47 pm
Running sweet as, no misfires thats what's concerning me
Post Posted: Sat Sep 10, 2011 10:50 pm
I only noticed it as I saw a strange ominous orange glow from the rear on the highway the other night
Post Posted: Sat Sep 10, 2011 10:52 pm
No ethanol, just 98 octane, if I do find the cause I'll let u know
Post Posted: Sat Sep 10, 2011 10:53 pm
The video isn't playing.
I'd be a bit concerned you have a sticking injector - there is no way on a stationary car there should be enough excess fuel lying around to cause a flame, especially with EFI.
It might happen if you snap the throttle shut from high revs/high load, but no way when free revving.
If it's a sticking injector you need to get it sorted quick - if could flood the motor and hydraulic it.
Maybe a misfire, but it would have to be an epic missfire. I was at the Pines Enduro last weekend and the top buggies flatshift - a momentary ignition cut whilst they slam the gear through. Even at 8000rpm and 800HP they don't flame on the shift, but t hey do flame on overrun.
PS are you running a toyota computer?
Steve
Post Posted: Sat Sep 10, 2011 10:58 pm
I've changed the link try that
Post Posted: Sat Sep 10, 2011 11:08 pm
That wouldn't be ye old spark plug in the exhaust trick is it?
http://www.youtube.com/watch?v=-YiU-nwZ ... re=related
'92 Vitara & Camper trailer
Post Posted: Sat Sep 10, 2011 11:12 pm
I wish, no in all seriousness it's real and I'm up for any ideas as to what it may be to rectify the problem
Post Posted: Sat Sep 10, 2011 11:29 pm
My rotar does that. Brings the coolness. Started a grass fire once. That was pretty fun.
Post Posted: Sat Sep 10, 2011 11:30 pm
I've just moved rural and really don't need that
Post Posted: Sat Sep 10, 2011 11:32 pm
I would say check your timing, Air fuel ratios, spark and injectors. I'm sure that is caused by fuel being dumped through the exhaust.
I have some bigport 4age injectors here if you need to test them.
Post Posted: Sat Sep 10, 2011 11:44 pm
Cheers mate I'll get under the bonnet this arvo, if I need the injectors I'll sing out
Post Posted: Sat Sep 10, 2011 11:50 pm
are you running the latest in anit-lag technology, like that WRC cars?
that is cool, but it can't be good for the motor or you cat converter. 8O
Post Posted: Sat Sep 10, 2011 11:57 pm
Stick as a rock everything motor ecu afm injectors, Except the fuel pump
Cat converter ??? What cat converter?
Post Posted: Sun Sep 11, 2011 12:01 am
I think Gwagen is on the money. I don't know how the Age injectors are, but this can happen to a vit TBI system when the O-ring or seal goes bad, it pumps fuel right down the throttle body.
Is it possible your high pressure pump is overpowering the injectors?
How is your fuel return line setup, and what are you using for a return?
Post Posted: Sun Sep 11, 2011 12:13 am
Return is 5/16 stainless from a 2l surge tank
As for the h/p pump over powering injectors makes a bit sence and could be possible as Im not running a fuel pressure regulator
Post Posted: Sun Sep 11, 2011 12:32 am
Post Posted: Sun Sep 11, 2011 12:39 am
I keep picturing a bright green drover hammering down the highway with a 2ft flame out the arse. I have laughed a few times now at your vid. You really know how to stir it up!
Post Posted: Sun Sep 11, 2011 12:46 am
this
Post Posted: Sun Sep 11, 2011 12:51 am
But surely there's a stock reg on the fuel rail? It's not possible to run with no reg
The flames are a recent change?
I agree that in theory the stock reg could be being overwhelmed by the flow of the Bosch pump. Checking fuel pressure at the rail would be the obvious way to check, but if this is the case and fuel pressure was high enough to push flames, then the car should be running massively rich under power, probably to the point it will bog.
I've had lots of fuel pressure issues with my 660 and if fuel pressure goes up by 10psi the drivability goes to poo.
Vehicle: Ducati Monster
Post Posted: Sun Sep 11, 2011 12:53 am
either way i love it, i had a TT600 that used to do this, sorry mate i never bothered finding out what did it to that either, used to freak the horses and cattle i had on my place when it went off though
Post Posted: Sun Sep 11, 2011 12:59 am
I'm not running an afternarket furl press reg,
It probably has one built into the fuel rail one the engine I don't know
Yes it does flame condinuisly kruzin if it given the berries round 6500 rpm.
And IT has NEVER done this and ran like the clappas for the past year and still does, no power diff what so ever
This is my concern
Post Posted: Sun Sep 11, 2011 1:04 am
You haven't recently had the fuel tank/system out? Had any rocks/logs jam up under the car? is it possible the return fuel line has become crimped? That would up the fuel pressure heaps.
Getting any trouble codes?
IMHO it's got to be base fuel pressure or a sticking injector.
Post Posted: Sun Sep 11, 2011 1:12 am
I'll be checking the return line this arvy I did bottom out pretty hard on Friday
And I'll be checking all the injectors aswell see how that goes
Thanks guys for all ur input
Cheers kermy87
Post Posted: Sun Sep 11, 2011 4:36 am
pull the plugs out and compare them if its only one injector causing the prob you will see which one it is, but if it was just one i think you would have a miss down low for sure. if its there all the same has to be fuel pressure like steve said.
Users browsing this forum: Google [Bot] and 31 guests
