| locka help http://auszookers.com/forum/viewtopic.php?f=5&t=25694 |
| Author: | sicktara [ Sun Sep 11, 2011 9:18 am ] |
| Post subject: | locka help |
hey guys looking at getting the lockas in the rear on my 89 swb vitara. proble from low range, my question is, do i need the couplers or not? do i need to know the spline size? nstupid questions but i have no idea on this one. any other places i should look at? cheers jordan |
| Author: | Manaroo12 [ Sun Sep 11, 2011 9:23 am ] |
| Post subject: | Re: locka help |
Hi Sicktara There are a number of threads on your question in the tech section cheers martin |
| Author: | sicktara [ Sun Sep 11, 2011 9:33 am ] |
i cant find them :/ still getting use to this site |
| Author: | joe5701 [ Sun Sep 11, 2011 9:40 am ] |
http://www.auszookers.com/index.php?nam ... locker+vit try this, it might help |
| Author: | Built4thrashing [ Sun Sep 11, 2011 10:18 am ] |
Order yourseld a 1510 lockright. its the same as the 1512 but comes with sierra cross pins that you wont need. |
| Author: | skyman [ Mon Sep 12, 2011 8:32 am ] |
I can not remember which, but I have heard rumor one engages and disengages better than the other. I can not remember if it is the one that comes with the couplers, or the one that re-uses your side gears. I am sure someone will come along and tell us which is better (if it is not just all in the setup). I am not 100% but I believe your front diff will have 22 spline side gears and axles, the rear will always be 26 spline. You may want to look for a steel front diff when you can. They hold up better than the ally ones. |
| Author: | Built4thrashing [ Mon Sep 12, 2011 9:18 am ] |
the one with couplers is really hard on the driveline. Best to use the 1510 that uses your side gears. |
| Author: | shabz [ Mon Sep 12, 2011 10:39 am ] |
Im going through this at the moment aswell. Did some googling and found that using the stock side gears allows a smoother locking/unlocking, compared to using the couplers which are more agressive |
| Author: | shandy92 [ Mon Sep 12, 2011 11:14 am ] |
shabz wrote: Im going through this at the moment aswell.
Did some googling and found that using the stock side gears allows a smoother locking/unlocking, compared to using the couplers which are more agressive x2, i run the one without the couplings, just make sure you get someone decent to install it for you. will decide whether your car will stay a pleasure to drive or become a pig to drive. |
| Author: | dave91 [ Mon Sep 12, 2011 11:21 am ] |
would 1510 work in a lwb too? |
| Author: | shandy92 [ Mon Sep 12, 2011 11:27 am ] |
dave91 wrote: would 1510 work in a lwb too?
cant see why it wouldnt, its the same differential. but im sure some one will correct me. |
| Author: | sicktara [ Tue Sep 13, 2011 8:44 am ] |
so just orderthe 1510? |
| Author: | shandy92 [ Tue Sep 13, 2011 1:29 pm ] |
i dont want to be the one to make the decision for you but yeah. have a look on the lowrange offroad (i think) website and choose your model vit, then choose the locker WITHOUT couplers. enjoy |
