It is currently Mon Sep 28, 2026 3:20 am
lesspostingmorewheeling
Post Posted: Thu Jul 24, 2008 4:29 am
i did an oil change the other day and i used nearly 4 litres of 20/50 weight castrol gtx for older motors and i just read on the bonnet that it says to use 15/40 weight is the oil i'm using too thick? should i change it?
cheers
Post Posted: Thu Jul 24, 2008 11:05 am
should be right, but if it's blowing smoke, the thinner oil will make it worse
Post Posted: Thu Jul 24, 2008 11:07 am
gtx is pretty shit quality oil, thicker oil isnt harder to burn, better oils are
I would try and get your mixtures checked 1st as you may be running rich and washing the oil off the bores and burning that
Post Posted: Thu Jul 24, 2008 12:05 pm
Definitly change the oil for a good quaility 15w40. When it says 'for older engines' it really means pre 1940's cars :lol: . You could even use a semi-synthetic 10w40 if you really wanted to, but don't use anything thicker than 15w40. It won't do any sort of damage using thicker oils, it just won't run as efficiently.
Post Posted: Fri Jul 25, 2008 1:29 am
due to amount of kilometers 230000klm i use penrite 30 which seems to be ok :!:
Post Posted: Fri Jul 25, 2008 1:33 am
my odometer says 191,000ks but the speedo cable was broken for a few thousand ks
so do i need to change the oil again now or would it be alright for a while longer?
Post Posted: Fri Jul 25, 2008 1:45 am
If it was mine I would go ahead and change it now... but that's just me.
Post Posted: Fri Jul 25, 2008 1:47 am
i'm spending more money on oil than petrol :lol:
will i need another new filter?
Post Posted: Fri Jul 25, 2008 2:16 am
i change my oil/ oil filter & fuel filter every 5000k as cheap insurance.
Post Posted: Fri Jul 25, 2008 2:17 am
i've changed mine twice on a quarter of a tank of fuel :lol:
Post Posted: Fri Jul 25, 2008 2:24 am
how much it cost you to do that andrewa and how long time wise does it take you to do 5000k
Post Posted: Fri Jul 25, 2008 2:27 am
hi
hello
Post Posted: Fri Jul 25, 2008 2:31 am
a filter is like 20 bucks and the oil would maybe be 50?
Post Posted: Fri Jul 25, 2008 11:38 am
You own a Zook, that's just part of life. :lol:
Don't worry about the filter.
Post Posted: Fri Jul 25, 2008 11:39 am
_noddy wrote:
hi
WTF???????
Post Posted: Sat Jul 26, 2008 2:13 am
hey zookfan. cost is about $55 & generally twice a year, so approximately every 6 months.
Post Posted: Sat Jul 26, 2008 2:30 am
that is cheap insurance then i was gonna say if you used the vehicle for longer k's it may be cheaper to save for a new engine and do the oil every 10-15k but yeah 6 months is ages
Post Posted: Sat Jul 26, 2008 2:53 am
i'm actually saving for a motor in the new year. 1600 bottom end with 1300 head. that's the plan anyway!!!!!!!!!!!!
Users browsing this forum: Google [Bot] and 123 guests
