| 93 Sierra, engine problems. http://auszookers.com/forum/viewtopic.php?f=5&t=25846 |
| Author: | primejo07 [ Fri Sep 16, 2011 2:04 am ] |
| Post subject: | 93 Sierra, engine problems. |
this is my first post! So, i drowned my sierra about two weeks ago. took water into the motor and had to take all the spark plugs out and crank the water out. as soon as i got home, i changed the oil and did a spark plug change. she drove like a dream for a week, but then it all changed. just out of the blue, she wouldnt idle. she would just start up and die. when it did idle, it would constantly fluctuate the revs by itself. now when im driving, unless its in gear with revs up, the motor just dies. as soon as i push the clutch in or put it in neutral, the revs drop rapidly and the engine dies. im honestly mind boggeled on whats going on, ive tried everything i can think of. does anyone have any idea whats going on? Cheers heaps! |
| Author: | Reubs [ Fri Sep 16, 2011 2:13 am ] |
| Post subject: | Re: 93 Sierra, engine problems. |
Your problem sounds carby related - possibly either the idle jet is clogged or the fuel cutoff solenoid is playing up. I'm sure a 'real' mechanic will post up and advise the best fixes for those problems. |
| Author: | primejo07 [ Fri Sep 16, 2011 2:19 am ] |
thanks reubs, im pretty short for cash at the moment, so im trying to sort out my problems myself alright, ill hang on in there for now |
| Author: | jmd-247 [ Fri Sep 16, 2011 2:19 am ] |
i had a similer problem after i did the same thing. my idle solenoid was all gummed up.. gave it a clean with wd40 etc to clean it out and have had no troubles since. i think the muddy water dired it out.. |
| Author: | Teracis [ Fri Sep 16, 2011 2:21 am ] |
If u sunk it have you checked there's no water in your fuel? |
| Author: | SuziBlu [ Fri Sep 16, 2011 2:24 am ] |
Teracis wrote: If u sunk it have you checked there's no water in your fuel?
X2, also strip ya carb down and drain it, also do your fuel filter, then bung some methanol thru it. |
| Author: | primejo07 [ Fri Sep 16, 2011 2:25 am ] |
jmd-247 - ahh i didnt think of that! so you just unplugged it, unscrewed it and gave it a bit of a spray eh? cheers heaps ill go do that now!
Teracis - Yeah mate, i took the fuel tank off, drained it, cleaned all the fuel lines too. it was a good idea actually, they get pretty scummy down there |
| Author: | primejo07 [ Fri Sep 16, 2011 2:39 am ] |
alright, so i just did the solenoid, no noticable difference.. but after playing around with it, it seems like it actually doesnt work... haha so mabye thats half my problem. strip the carb and the fuel filter down now, and see how i go |
| Author: | primejo07 [ Fri Sep 16, 2011 4:23 am ] |
this is the 'puddle' that got me stuck... well not me, i was letting my mate drive. big mistake! |
| Author: | FullyZooked [ Fri Sep 16, 2011 4:46 am ] |
Oh my... Your friend is an arsehole! Hahaha! |
| Author: | ZookFan [ Fri Sep 16, 2011 6:12 am ] |
now thats a bit deep |
| Author: | TasRat [ Fri Sep 16, 2011 9:06 am ] |
did you drop the diff, gearbox & transfer oils? I sunk mine similar engine was fine (drove it home) but everything else was a chocolate milkshake, even with breathers. wrecked engine, diff, and wheel oil seal too, turned into an expensive swim, |
| Author: | primejo07 [ Tue Sep 20, 2011 12:30 am ] |
how expensive are we talking here ? :S Ill drop the diff, gearbox and transfer oils tonight and see how i go. |
