It is currently Mon Sep 21, 2026 7:35 am
Post Posted: Mon Sep 19, 2011 12:03 pm
got a few sets of maruti 4.1 diff centeres laying round and thought i'd throw some under my new w/t rig, the only prob is they are n/t bolt pattern on the flanges. Can i redrill the flanges to suit w/t spacing, i have a tailshaft spacer that has both patterns on it and would be perfect for the task, or am i going to end up cursing cause i cant drill through the flange
(no drill press either)
Post Posted: Mon Sep 19, 2011 12:12 pm
put wide track flanges on them? thought they were interchangeable?
Post Posted: Mon Sep 19, 2011 12:16 pm
take them to a machinist and tell them the PCD you want. Chucking the flange up on a roatary table in a Mill will take them 5-10 mins to do the job. Probably get it done for a 6pack if you drop in on friday morning :wink:
Post Posted: Mon Sep 19, 2011 12:17 pm
yeah they are, but they arnt fun to get off
thought this way would be easier and quicker to drill 8 holes than to spend ages with breaker bars and shit on my own.
Post Posted: Mon Sep 19, 2011 12:21 pm
the spacer i have has both sets of holes, i thought it would be easier to bolt it on and then just drill through the w/t holes which should give the perfect pcd ? uh
Post Posted: Mon Sep 19, 2011 1:10 pm
i have wt ones and drilled nt holes in them i used the spacer as a jig and it worked well
josh AKA Bazook
Post Posted: Mon Sep 19, 2011 1:30 pm
Same, i drilled my large pattern vit diffs to the smaller pattern Sierra.. no dramas, and lots of road miles at 100Km.
Post Posted: Mon Sep 19, 2011 1:33 pm
Haha look at Sky converting from miles for us simple Aussies :lol: :lol: :P
Post Posted: Mon Sep 19, 2011 3:14 pm
Yeah you caught me, just doing my best to fit in, aye. armsup
Post Posted: Mon Sep 19, 2011 7:32 pm
use a bearing puller to remove flanges.
Vehicle: Vitara G16b , Sierra G16b
Post Posted: Mon Sep 19, 2011 11:06 pm
Just swap the yokes over to N/T.
Post Posted: Tue Sep 20, 2011 8:09 am
ok i cannot see how this would work as the actual flanges themselfs are a different size and the pcd of the w/t is on the outer edge of the n/t flange
so it looks like they will be swaped by suzistore.
Post Posted: Tue Sep 20, 2011 8:22 am
There wont be enough meat on them to drill for the bigger wt pcd. Wt's are bigger.
Post Posted: Wed Sep 21, 2011 6:57 am
You already do mate!!! :helloo:
Post Posted: Wed Sep 21, 2011 7:26 am
Thanks mate, believe or not that means allot to me.
Post Posted: Wed Sep 21, 2011 7:30 am
maby run NT Flange on Diff side and WT and Transcase side ? just change the Drive shaft joints to suit ?
im sure u cant get a Flange new Flange from Low range i think they sell NT flanges with 5 WT patten would something like this work ? http://www.lowrangeoffroad.com/index.ph ... pters.html
Users browsing this forum: No registered users and 186 guests
