| Lowering a zook. http://auszookers.com/forum/viewtopic.php?f=5&t=26008 |
Page 1 of 2 |
| Author: | stockman [ Wed Sep 21, 2011 9:22 am ] |
| Post subject: | Lowering a zook. |
I want to lower my zook as it's sitting to high. I only have a 40mm lift, but would like to bring it back to stock height. Running OME's all round will it drop the ride height if I remove a leaf from each pack? |
| Author: | Joe [ Wed Sep 21, 2011 9:26 am ] |
| Post subject: | Re: Lowering a zook. |
Why not just put stock springs in? |
| Author: | tobeszook [ Wed Sep 21, 2011 9:27 am ] |
but why ? |
| Author: | stockman [ Wed Sep 21, 2011 9:38 am ] |
Joe wrote: Why not just put stock springs in?
I like the flex of the OME's, but that is an option. |
| Author: | stockman [ Wed Sep 21, 2011 9:39 am ] |
tobeszook wrote: but why ?
Why what? |
| Author: | atari4x4 [ Wed Sep 21, 2011 9:40 am ] |
how low do you want to go? could you not remove 2 leaves & add on stock one to to each pack? (if you've got any stockies? |
| Author: | alien [ Wed Sep 21, 2011 9:42 am ] |
taking a leaf out would do it, but you'd potentially get handling issues, and you'll need to check the shocks wont bottom out on compression. another option being that you're SPUA is lowering blocks between the leaf and the diff =P hahaha |
| Author: | stockman [ Wed Sep 21, 2011 9:43 am ] |
I'd like to go 30-40mm lower. I do this have stock springs so that is another option. |
| Author: | joel [ Wed Sep 21, 2011 9:43 am ] |
stockman wrote: tobeszook wrote: but why ? Why what? if its only 40mm lifted, why bother lowering it anymore? low is the new cool, but a lowriding zook is ghey. |
| Author: | stockman [ Wed Sep 21, 2011 9:44 am ] |
alien wrote: taking a leaf out would do it, but you'd potentially get handling issues, and you'll need to check the shocks wont bottom out on compression.
| Author: | alien [ Wed Sep 21, 2011 9:45 am ] |
swap the stock main leaf with the OME one, so you have the OME main and stock pack underneath... then you get the longer leaf and flatter spring. i drove a stock sierra on the weekend (suspension was stock, engine was 1.6efi - it hauled ass on stock tyres!!) the ride from stock leaves is best described as "the bumpiest fucking ride of your life" IMO.. |
| Author: | stockman [ Wed Sep 21, 2011 9:46 am ] |
joel wrote: stockman wrote: tobeszook wrote: but why ? Why what? if its only 40mm lifted, why bother lowering it anymore? low is the new cool, but a lowriding zook is ghey. To lower the cog. Lowering it 30-40mm will hardly make it a lowrider. |
| Author: | joel [ Wed Sep 21, 2011 9:46 am ] |
just buy a mini moke, that should be low enough. |
| Author: | joel [ Wed Sep 21, 2011 9:48 am ] |
stockman wrote: joel wrote: stockman wrote: tobeszook wrote: but why ? Why what? if its only 40mm lifted, why bother lowering it anymore? low is the new cool, but a lowriding zook is ghey. To lower the cog. Lowering it 30-40mm will hardly make it a lowrider. a 40mm lift will hardly make it a high cog. maybe a 40mm lift, 2'' shackles 3''bl and your best driving suit with matching top hat. i reckon just leave it man, your fixing what isnt broke IMO |
| Author: | atari4x4 [ Wed Sep 21, 2011 9:49 am ] |
why bother? cause in 8 days 5 hours & 42 minutes you'll probably change your mind. |
| Author: | stockman [ Wed Sep 21, 2011 9:50 am ] |
joel wrote: just buy a mini moke, that should be low enough.
You obviously can't read or are retarded or quite possibly both. |
| Author: | joel [ Wed Sep 21, 2011 9:52 am ] |
stockman wrote: joel wrote: just buy a mini moke, that should be low enough. You obviously can't read or are retarded or quite possibly both. possibly, but im not trying to lower my 40mm lifted zook
| Author: | stockman [ Wed Sep 21, 2011 9:52 am ] |
atari4x4 wrote: why bother?
cause in 8 days 5 hours & 42 minutes you'll probably change your mind. This is quite possibly true, But on stock tyres I don't need to have 20" of guard clearance |
| Author: | ajsr [ Wed Sep 21, 2011 9:53 am ] |
joel wrote: stockman wrote: joel wrote: stockman wrote: tobeszook wrote: but why ? Why what? if its only 40mm lifted, why bother lowering it anymore? low is the new cool, but a lowriding zook is ghey. To lower the cog. Lowering it 30-40mm will hardly make it a lowrider. a 40mm lift will hardly make it a high cog. maybe a 40mm lift, 2'' shackles 3''bl and your best driving suit with matching top hat. i reckon just leave it man, your fixing what isnt broke IMO sounds more like you know a whole lot of fuck all about anything to me maybe help the guy , or dont bother fucking his thread. you could probably make a hybrid pack using the main ome leaf or two (to get the droop) and some standard leafs. you just have to play around to get the ride you want |
| Author: | atari4x4 [ Wed Sep 21, 2011 9:53 am ] |
a locked stocker with muds & long soft leaves would be a ball to drive. |
| Author: | canberramav [ Wed Sep 21, 2011 9:54 am ] |
I would put the stock ones back in. You will ruin the OME springs if you start flattening them out by changing in other leafs. |
| Author: | shep [ Wed Sep 21, 2011 9:55 am ] |
stockman wrote: atari4x4 wrote: why bother? cause in 8 days 5 hours & 42 minutes you'll probably change your mind. This is quite possibly true, But on stock tyres I don't need to have 20" of guard clearance but you dont |
| Author: | RIKSTR [ Wed Sep 21, 2011 9:57 am ] |
| Author: | joel [ Wed Sep 21, 2011 10:03 am ] |
ajsr wrote: joel wrote: stockman wrote: joel wrote: stockman wrote: tobeszook wrote: but why ? Why what? if its only 40mm lifted, why bother lowering it anymore? low is the new cool, but a lowriding zook is ghey. To lower the cog. Lowering it 30-40mm will hardly make it a lowrider. a 40mm lift will hardly make it a high cog. maybe a 40mm lift, 2'' shackles 3''bl and your best driving suit with matching top hat. i reckon just leave it man, your fixing what isnt broke IMO sounds more like you know a whole lot of fuck all about anything to me maybe help the guy , or dont bother fucking his thread. you could probably make a hybrid pack using the main ome leaf or two (to get the droop) and some standard leafs. you just have to play around to get the ride you want that is my advice, just leave them in there i reckon, how old are the sprigs? if they have done a fair few kms they would have settled a bit, mine have and are nearly flat. i geuss if you have the spare time and what not, than do it. but i would just leave it, ome are nice springs and far better than stockers, if you pop a spring out of them they may be to soft and invert after a while like my old ones. |
| Author: | atari4x4 [ Wed Sep 21, 2011 10:08 am ] |
hey joel, you should sell him your calmini shackle reversal kit. |
| Author: | joel [ Wed Sep 21, 2011 10:10 am ] |
sad fact is, i still have it in the shed and havent binned it where it belongs the front end was so much smoother and softer with it in, pitty everything else about it is crap. |
| Author: | stockman [ Wed Sep 21, 2011 10:13 am ] |
ajsr wrote: you could probably make a hybrid pack using the main ome leaf or two (to get the droop) and some standard leafs. you just have to play around to get the ride you want canberramav wrote: I would put the stock ones back in. You will ruin the OME springs if you start flattening them out by changing in other leafs. Thanks guys, Exactly the input I was wanting to here. RIKSTR wrote: :roll:
| Author: | alien [ Wed Sep 21, 2011 10:13 am ] |
stockman, what rim offset do you run? widening it could be another option. mines pretty wide with 15x7 -38 rims and 31x10.5 tyres.
| Author: | stockman [ Wed Sep 21, 2011 10:15 am ] |
Just standard rims, not sure on the offset. I don't really want a big off set rims, as with narrow tyres I'm just going to fall into the ruts. |
| Author: | alien [ Wed Sep 21, 2011 10:20 am ] |
ah, righto... hey if fabrication is your thing you could make lower spring mounts off the chassis, and set the shackle end up like this, but not in reversal:
