It is currently Tue Oct 13, 2026 11:36 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
Vehicle: Sierra Ute '87 Sj70
Post Posted: Thu Sep 22, 2011 3:06 am
Everyone one seems to either hate them or loves them and I wanna know reasonings both in theory and in prac. But if you have actually ran them please also say so. But also if you havent and you still got a opinion you can chuck that up here too.
Ps try not to start arguments!
Thanks guys
It's all coming together Armsup
Vehicle: '96 LWB trayback
Post Posted: Thu Sep 22, 2011 3:16 am
Firstly, I've never run lux diffs.
The arguments against being:
- The rear diff pumpkin is centred, which can introduce vibrations with the angled tailshaft back to the transfer case.
- The large diameter of the pumpkin will reduce diff clearance unless exceptionally large tyres are used (35" +).
- They are SPOA from the factory, and must be used in SPOA configuration to comply with the needs of most engineers.
Post Posted: Thu Sep 22, 2011 3:24 am
Sorry mate by me saying hilux diffs I mean hilux/bundy diffs and has anyone measured the pumpkins? I just wanna see comparison sizes
What about if you shaved them how much meat can you shave out of he hilux diff compared to a zook diff?
Post Posted: Thu Sep 22, 2011 3:34 am
My Arguments for:
Greater strength than wt with chromo axles and alot of parts are easily upgradeable with off the shelf parts
More steering options
Pumpkin/housing is not much bigger than wt sierra's But can be shaved for more clearance
Rear bundera diff can be used to align driveline better in rear. Still using hilux centre
Still legal in Nsw, not Qld.
Heavier than sierra's. Can be a pro and a con.
Wider for more stability
Post Posted: Thu Sep 22, 2011 3:37 am
Legal with mod plate ? Or can't get a mod plate for them?
Post Posted: Thu Sep 22, 2011 1:41 pm
No diff swaps in Qld allowed alltogether.
Legal in Nsw, but has to be engineered.
Post Posted: Fri Sep 23, 2011 8:57 am
you can do diff swaps in qld legally in other cars. i think its the fact of it being needed to be done spoa? and do ya need to change chassis configuration which is a big no no in qld?
Vehicle: Sj70 tintop
Post Posted: Fri Sep 23, 2011 9:07 am
not sure on legalities, but you can run them spring under, just have to change the perches, dont need to play with the chasis to run them.
Sj70 tintop
Post Posted: Fri Sep 23, 2011 9:18 am
My Arguments for:
X2 done and dusted.
Post Posted: Fri Sep 23, 2011 7:24 pm
aren't bundera diffs spring under anyway? there is a 75series sitting in my drive way and it is spua. on 31 it has bugger all clearance and it gets stuck very easily but that is with it big leaves. i have alot more clearance on 235 75 15 in my vit than it does.
Post Posted: Fri Sep 23, 2011 7:27 pm
Nope bundy are coil sprung or spoa.
Post Posted: Sat Sep 24, 2011 2:56 am
Bundera come coils only in Aus. Toyota landcruiser LJ70/RJ70
Toyota Landcruiser BJ70 Are Leaf, Spua.
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sat Sep 24, 2011 3:49 am
id rather patrol diffs over hilux diffs, patrol diffs are alot stronger for running larger tyres IE 40inch +.
95 Sierra SJ70 TinTop
Post Posted: Sat Sep 24, 2011 3:50 am
true, but if the rig is that wild to run huge diffs on 40's.... i reckon some uni mog diffs would be better.
i want a uni mog. 8)
Sj70 tintop
Post Posted: Sat Sep 24, 2011 4:05 am
Would 60 series diffs still not be a more sensible option than hilux?
Post Posted: Sat Sep 24, 2011 4:07 am
kinda sorta. the pumpkin is a fair amount bigger, so you loose some ground clearance.
but if your running 40's..... not really a prob.
Sj70 tintop
Vehicle: 03 Jimny
Post Posted: Sat Sep 24, 2011 4:31 am
Yes but less aftermarket part for patrol diffs
Post Posted: Sat Sep 24, 2011 4:43 am
theres air lockers, different ratios, what else can you do with them?
they shouldnt break.
Sj70 tintop
Vehicle: 03 Jimny
Post Posted: Sat Sep 24, 2011 4:53 am
Theres more ratios for a hilux diff as far as I know.
Post Posted: Sun Sep 25, 2011 1:56 am
This argueing is getting annoying. Everyone has their own thought on what is better and they all want to win.
60' diffs
Pro's:
Alot of gearing options
Alot of steering options(same as lux bits)
Alot of hub bits (same as lux)
Axles can be upgraded with off the shelf parts
Stronger centres than hilux due to size.
Full floating rear(major pro)
Rear is offset for zook transfer
Pro and con:
Cheap
Heavier than zooks
Larger pumpkin, good for centre strength, but no good for clearance, can be shaved.
Same cv size as lux. So basically same strength as lux altogether up front.
Not much wider than lux
Vehicle: 03 Jimny
Post Posted: Sun Sep 25, 2011 2:23 am
Who's arguing :? :roll:
Post Posted: Sun Sep 25, 2011 2:36 am
has any one actually measured the clearance of a hilux pumpkin? i have
measured a early hj75 (big diff model) diff clearance and the hj on
33s has the same clearance
as a sierra on 31s so that is approximately 25mm less clearance for the HJ if on the same tyres.
i bet hilux diff clearance would be so close to a sierra that the difference would be irrelevant especially when the
extra width and strength is taken into account.
Vehicle: 75 Cruiser
Post Posted: Sun Sep 25, 2011 3:04 am
yes .. hilux diff is 10 - 12mm less clearence than sierra.
Post Posted: Sun Sep 25, 2011 3:40 am
so fuck all then :wink:
Post Posted: Sun Sep 25, 2011 3:47 am
and a good shave would bring it back to sierra size. 8)
Post Posted: Sun Sep 25, 2011 3:48 am
but wouldnt you be able to shave more out of the hilux diff anyways?
Post Posted: Sun Sep 25, 2011 3:49 am
Vehicle: 75 Cruiser
Post Posted: Sun Sep 25, 2011 5:03 am
yeah... tyre pressures could be the difference :lol:
Post Posted: Sun Sep 25, 2011 6:36 am
Although I like the Hilux diff option here are some other things to consider:
1. Hilux rear diff at 1420mm is only 120mm wider overall than a WT Sierra
with is 1300mm wide.
2. Hilux diff (complete) is twice the weight of a WT Sierra diff, adding so much weight to your nimble Suzuki may detract from its agility.
3. Due to weight and size a Hilux Diff robs a significant amount of power from the vehicle especially if you intend to use it on road. Gearing can correct it but you rob from peter to pay paul, needing higher rpm to achieve highway speeds.
4. The added weight places undue stress on all suspension mounting points which were designed for a much lighter diff. (There is a video somewhere on the site with a hilux diffed suzuki rolling over backwards when under power up a steep track the diff rips the spring mounts from the chassis)
5. The size of the pumpkin is not the only factor in reduction of ground clearance, the diameter of the Hilux diff tube is 25mm bigger (OD) than a WT Sierra so if you are doing a spring under axle after you weld the saddles on the housing the centre of the axle will be 12.5mm up closer to the guard. Or if you look at it the other way the spring will be 12.5mm lower in comparison to the centre of the axle than it would be in a WT Sierra axle.
6. Suzi-fan-22, it is not just the exterior that is bigger, the centre is bigger inside so you can't shave much off mate.
Post Posted: Mon Sep 26, 2011 10:54 am
My Arguments for:
X2 done and dusted.
x3.. Has been 100% reliable, much better whilst off roading, bloody love them!! ;)
Users browsing this forum: No registered users and 173 guests
