| Author |
Message |
Mike
lesspostingmorewheeling
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
 Posted: Wed Sep 03, 2008 1:03 am |
my zook has an imobolizer that only works when the battery has been disconnected and i don't have a remote for it
how would i go about removing it?
royce
 Posted: Wed Sep 03, 2008 1:35 am |
why would you need an immobiliser if the battery is disconected? its already immobilised
1st step is to find it, 2nd step is to find where its been tapped into and then any factory wires that have been looped through it to rejoin
Mike
 Posted: Wed Sep 03, 2008 2:09 am |
it starts working when you connect the battery then the idicators flash and you can't start the car
where is the most common place they put them?
SuperRoo
Joined: Wed Apr 16, 2008 11:30 pm Posts: 86 Location: Perth WA
 Posted: Wed Sep 03, 2008 6:30 am |
Most are mounted under the drivers side dash, usually around the steering column area.
If its a name brand immobiliser like Laserline.... then it should only have black wires going into it making it a little hard to disable.
royce
 Posted: Wed Sep 03, 2008 11:04 am |
just listen for it ticking with the indicators
see if you can find a small switch wired into it, turn the ignition on and flick the switch (may be a button) and it will override it
Rockhopper
Joined: Sun Jun 22, 2008 11:30 pm Posts: 1265 Location: Chipping Norton
 Posted: Wed Sep 03, 2008 11:09 am |
They are usually wired into the ignition switch wiring so look for any factory wiring that has been cut and has (usually thinner) aftermarket wiring wired into it. If it's like most of the immobolizers I've had the displeasure of looking at over the years, there will be a birds nest of wiring under your dashboard.
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Wed Sep 03, 2008 11:18 am |
Rockhopper wrote: If it's like most of the immobolizers I've had the displeasure of looking at over the years, there will be a birds nest of wiring under your dashboard.
If it's like most of the zooks i've seen over the years, there will be a birds nest of wiring under your dashboard.
_________________ SJ50.4.LYF
Fluffy
Joined: Thu Jul 19, 2007 11:30 pm Posts: 892 Location: Picton, NSW
Vehicle: 105 landcruiser
 Posted: Wed Sep 03, 2008 12:27 pm |
i had same problem with my premier.. all of a sudden you would be at the lights ..have some sort of voltage fluctuation and the alarm would go off.
the horn was removed so it didnt make any sound.. the olnly way to turn it off was disconect the battery a few times...and it would also turn on when the battery was disconected.....
for a while (still am) i was runnin just a hot wire to the coil..  easiest fix
was a pain it the ass removing it and I'm left with spahetti and a massive massive headache even looking at rewireing it :'( main reason why its not mobile at the moment
BAZZOOK
Joined: Sat Mar 24, 2007 10:30 pm Posts: 1052 Location: MORNINGTON. VIC
 Posted: Wed Sep 03, 2008 3:14 pm |
WHILE ON THIS SUBJECT HOW DOES EVERYONE PROTECT THEIR RIGS FROM THEFT.
THIS IS MY CURRENT SYSTEM. MIGHT UPGRADE IT SOON TO HI TENSILE CHAIN.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Wed Sep 03, 2008 3:58 pm |
In the year and a bit I have had my Zook I've never once had it tampered with. I don't usually bother locking it either. Maybe it is just where I live??
Fluffy
 Posted: Wed Sep 03, 2008 4:10 pm |
ScrawnC wrote: In the year and a bit I have had my Zook I've never once had it tampered with. I don't usually bother locking it either. Maybe it is just where I live?? hmm good to know
maybe you should invest in one of these Anti theft devices
Scrawny
 Posted: Wed Sep 03, 2008 4:13 pm |
I reckon that would deter any would-be thief
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Wed Sep 03, 2008 4:28 pm |
BAZZOOK wrote: MIGHT UPGRADE IT SOON TO HI TENSILE CHAIN.
dont bother then the you will have to upgrade the lock and it will just be a money pit.....
Bruce
Joined: Sun Jun 11, 2006 11:30 pm Posts: 4003 Location: Brisbane
 Posted: Wed Sep 03, 2008 5:00 pm |
_________________ [quote="royce"] I wouldnt mind insulating my rear
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Wed Sep 03, 2008 5:01 pm |
is that so they can't adjust the seat?
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Wed Sep 03, 2008 5:10 pm |
Who would want to steal it with that carpet anyways
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
Scrawny
 Posted: Wed Sep 03, 2008 7:16 pm |
I NEED A TRUNK MONKEY!!!!!
Won't need the chaperone version for a few more years but the other versions I could do with now
keechox
Joined: Sat Dec 29, 2007 10:30 pm Posts: 242 Location: launceston Tasmania
 Posted: Wed Sep 03, 2008 9:40 pm |
hahaha I need a trunk monkey!!!!!
Rockhopper
 Posted: Wed Sep 03, 2008 9:45 pm |
If my car is not in my driveway I'm either wheelin or it's within eyesight. Whilst it's in my carport, it's protected by my german shepard.
_________________ We're riding in the Ninky Nonk!
