http://auszookers.com/forum/
Rear diff jerking when I turn
http://auszookers.com/forum/viewtopic.php?f=5&t=26050
Author:  350hp4agte [ Thu Sep 22, 2011 9:40 am ]
Post subject:  Rear diff jerking when I turn
Hey, so when I turn tightish corners my car jerks around kinda sounds similar to a bugged cv, but defiantly coming from
The rear, also some times after Turning it makes a large bang noise.
Any ideas?
Author:  89_tintop [ Thu Sep 22, 2011 9:51 am ]
Post subject:  Re: Rear diff jerking when I turn
What kind of car?
Author:  hooki [ Thu Sep 22, 2011 9:53 am ]
auto locker?
Author:  350hp4agte [ Thu Sep 22, 2011 10:03 am ]
Sorry 84 zook swb hi top
And its no "auto locker" something is wrong
Author:  boostedbrick [ Thu Sep 22, 2011 10:12 am ]
May have lost a tooth or two from a sun gear or something... Try drain your oil and see if you can find anything in it..
Author:  Vits93 [ Thu Sep 22, 2011 10:13 am ]
Does it make any noises? It might be spider gears in the diff jamming on the tight turns from worn washers/shims, bad/worn teeth.
Author:  350hp4agte [ Thu Sep 22, 2011 10:25 am ]
Yeh sounds exactly the same as a bugged cv like clicking
Author:  11_evl [ Thu Sep 22, 2011 11:05 am ]
If it's when in 4wd and on road it's more than likely transfer wind up
Author:  350hp4agte [ Thu Sep 22, 2011 11:57 am ]
Nah not in 4b and no hubs locked
Author:  dave07 [ Thu Sep 22, 2011 3:52 pm ]
defiantly sounds like worn or broken teeth. like it was said before try draining the diff oil and check for metal shaving. Also feel the oil between ur fingers to see if its gritty
