It is currently Mon Nov 02, 2026 5:13 pm
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Mon Sep 26, 2011 11:33 am
Hey guys :D,
Long time reader, first time poster...
So I've got a '91 SJ70 Sierra with the usual 2'' lift with 29'' tyres, I also have fitted a snorkel and ripped the back seats out and made up a drawer system to store recovery gear and tools.
Just wanted some advice on where to go now, with mods and extras...
I was thinking maybe a winch bar and SPOA?
Cheers,
Post Posted: Mon Sep 26, 2011 11:39 am
any many ppl will tell u on here spoa will most likely be a bad idea it hard to setup right and many other things if i was u i would look at a rear locker auto locker are only about 250 to ur door and will take u a lot futher offroad
if u drive a loud toyota ute u drink rum
Vehicle: 03 Jimny
Post Posted: Mon Sep 26, 2011 11:44 am
Transfercase gears
Vehicle: SJ70 1993
Post Posted: Mon Sep 26, 2011 11:49 am
I put a weber in my sj70 1990, sounds great engine runs great but did my clutch backing out of the shed so havnt have a test run yet :(
Lock, Drop and roll
Post Posted: Mon Sep 26, 2011 4:33 pm
if i was in your shoes this is what i would do, in this order.
1. Rear Locker
2. RUF and longer shocks (front and rear)
3. Good set of 31's (MT)
4. Transfer gearing and appropriate transfer bracing
This setup will make your sierra a capable little rig. You could also put some extractors and a exhaust system on to provide a tiny bit more power. After this there are heaps of things you could do...powersteer, front locker, cromo cv's, 1.6L conversion etc.
As said above SPOA is hard to setup right and is illegal on WA roads. Keeping is SPUA will mean it's easy to return to stock if you need to get the car over the pits. You should definitely be able to fit some 31's with a 2inch spring lift and some gaurd hammering/cutting. These days keeping rigs nice and low seems to be the way to go.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Tue Sep 27, 2011 3:43 am
Oh, I was told SPOA was a good thing... guess he lied -_-
I've currently got $1500 to play with so anything within that range is good.
I forgot to add, I've already set up a dual battery system with a Redarc Soleniod :)
Also, what engine mods are the best to run with... I can a barely sit on 100kph on the highway and I want to coax some more power out.
What exactly do lockers do...?
thanks again!
P.S You guys reply fast!
Post Posted: Tue Sep 27, 2011 4:15 am
Transfer gears will get you back on track on teh highway and a lot better control off road
Then some sliders and other barwork
If you dont know what lockers do you dont need them yet
Vehicle: Yamaha scooter, 50cc
Post Posted: Tue Sep 27, 2011 4:24 am
For your money, IMHO you will see the best results from the following combination
Reduction gears (which will also assist your highway driving slightly by bringing your highrange ratios back to stock)
Rear auto locker, I recommend a spartan for ease of installation and use. A locker will keep both rear wheels turning in low traction situations, whereas an with and open diff all power is sent to the point of least resistance, ie when one one wheel starts spinning all power is sent to that wheel resulting in no drive to the other wheel, and you going nowhere fast
If you have any cash left over after that, get some extractors and a new zorst to help the asthmatic little engine breathe better
Hope this helps,
Nathan
Post Posted: Tue Sep 27, 2011 4:28 am
X2!!
The worst thing you can do to a 4wd is modify it before you know how to use it.
Forget the lockers for now. They are dangerous in inexperienced hands.
haha Royce im going to use that Quote haha :D
Post Posted: Tue Sep 27, 2011 4:29 am
X2!!
to right if i had lockers when i first got my zook i would have rolled it long time ago i just delayed the roll over haha :lol: got carryed away with bog laps :(
Post Posted: Tue Sep 27, 2011 9:48 am
Oh, haha
In know what they are now, had them in the old 80 series cruiser... never really knew what the were called :/
What brand should I go for the reduction gears?
If at first you don't succeed, get a bigger hammer
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Sep 28, 2011 1:51 am
get them from lowrange.
They are the best especially due to thier shipping. They open everything up and pack it as small as possible and use post rather than a courier.
http://www.lowrangeoffroad.com/index.ph ... -case.html
Ratio will depend on both tire size and what your driving. 4.9s are good all rounders up to 31". I ran 6.5s with 31s and it was really good.
here you can see them taking a nap under my car:
Post Posted: Wed Sep 28, 2011 6:19 am
Transfer gears
Cut guards
31
U don't need lockers yet they take all the fun out of driving
When u do need them get both at the same time because rear locker only in a Sierra SUCK
The ass end try to overtake the front end or tries to do back flips
Users browsing this forum: Google [Bot] and 64 guests
