| running 16s, will they let me run bigger v6 gv brake caliper http://auszookers.com/forum/viewtopic.php?f=5&t=26198 |
| Author: | wideaz [ Tue Sep 27, 2011 9:58 pm ] |
| Post subject: | running 16s, will they let me run bigger v6 gv brake caliper |
i have a coily and looking to do a rear disk brake conversion and wondering cause i have 16s can i run the bigger rotors and calipers out of the gv v6 please let me know asap or i will just run normal coily brakes front and rear thanks heaps guys |
| Author: | Reubs [ Tue Sep 27, 2011 10:27 pm ] |
| Post subject: | Re: running 16s, will they let me run bigger v6 gv brake cal |
Dunno about the GV brakes but, A bolt-on upgrade is calipers and rotors from the LWB 1.6Vit. They are the same size as the standard coily but vented. |
| Author: | Fatzook [ Tue Sep 27, 2011 11:10 pm ] |
The SV and GV rotor offsets are different to sierra and vitara, so they are not a straight swap. The SV 2.0L rotors need a 7.5mm spacer behind them, and a stud upgrade. The SQ GV rotors are an even worse offset, and IMO not worth the effort. Just stick to the tried and tested 1.6LWB vit front setup. |
| Author: | wideaz [ Tue Sep 27, 2011 11:16 pm ] |
FATZOOK you are a legend thanks heaps guys |
| Author: | Fatzook [ Tue Sep 27, 2011 11:19 pm ] |
wideaz wrote: FATZOOK you are a Purist!
thanks heaps guys Fixed it before anyone else does. |
| Author: | steak_knife [ Wed Sep 28, 2011 7:08 am ] |
Fatzook wrote: wideaz wrote: FATZOOK you are a Purist! thanks heaps guys Fixed it before anyone else does. |
