It is currently Sat Oct 10, 2026 3:12 pm
Vehicle: Jimny, Lifted on 30's
Post Posted: Wed Sep 28, 2011 8:30 am
So my tierod boot rubbers on all of my steering components have evaporated over the last 30 years. I bought some new ones and tried to remove the steering arms etc, to replace all the 6 rubbers.
I had no luck moving them at all. Should you be able to undo the bolt and drop them out the bottom? Or is there some tricky way i need to do this to replace the rubbers?
Thanks
Nick.
:helloo:
Jimny, 3" Lift, 30" Treps, Gears
Vehicle: Vitara 90'
Post Posted: Wed Sep 28, 2011 8:48 am
I usually have to put a bit of metal on top of the nut (a little bit smaller so you don't screw the thread) and wack the shit out of it with a hammer.
Also there are spreader tools you can get too
Post Posted: Wed Sep 28, 2011 9:22 am
http://www.google.com.au/imgres?q=ball+ ... pVW&zoom=1
Post Posted: Wed Sep 28, 2011 9:26 am
Hit the side of the tie rod itself, they are a very tight tapered fit. The shock of hitting the side of them is usually enough to free them up :wink:
Post Posted: Wed Sep 28, 2011 9:30 am
You mean hit the knuckle arm on the side where the tapered pin passes through :wink: If you hit the tie rod it won't do shit. :lol:
Post Posted: Wed Sep 28, 2011 9:31 am
That's what I said :roll: :lol:
Vehicle: LWB Sierra & XL7
Post Posted: Wed Sep 28, 2011 1:10 pm
I did mine the other day.
http://www.auszookers.com/index.php?nam ... ht=tie+rod
'92 Vitara & Camper trailer
Post Posted: Wed Sep 28, 2011 6:17 pm
You'll stuff the ball joint if you do it this way. Hit the arm as Rusho suggested. Get a big hammer and pretend it just broke into your house and pinched all your stuff.
Post Posted: Wed Sep 28, 2011 8:33 pm
Either get a puller/separator - and please no "pickle forks" - or - get two hammers - place one on each side of the eye and then "clap" - or strike the knuckle on both sides simultaneously - this shocks the pin from taper.
Vehicle: Vitara 90'
Post Posted: Wed Sep 28, 2011 9:54 pm
I don't see how it'd stuff the ball joint any more than hitting the arm? I would have thought it'd be better than hitting the arm because you will only have vertical movement, all your doing is hitting the part that's stuck not the part that's attached to it.
Post Posted: Thu Sep 29, 2011 12:25 am
You'll end up squashing/damaging the thread and nut. If you hit the arm it gives the right amount of shock in the right place to loosen the taper
Vehicle: Vitara 90'
Post Posted: Thu Sep 29, 2011 12:44 am
That's why I use a piece of metal that is slightly smaller so you don't touch the thread. I take the nut off first too.
Either way you'd get the wanted result. :D
Post Posted: Thu Sep 29, 2011 7:36 am
Awesom thanks guys i think ill try the two hammer approach and get back to youse!
Post Posted: Sun Oct 02, 2011 4:56 am
Thanks for your help guys, got them all out and changed over today!!!!!!! took about 1 hour to do six :D!
Users browsing this forum: No registered users and 324 guests
