| Tierod Boot rubbers?? http://auszookers.com/forum/viewtopic.php?f=5&t=26224 |
| Author: | Mubby [ Wed Sep 28, 2011 8:30 am ] |
| Post subject: | Tierod Boot rubbers?? |
So my tierod boot rubbers on all of my steering components have evaporated over the last 30 years. I bought some new ones and tried to remove the steering arms etc, to replace all the 6 rubbers. I had no luck moving them at all. Should you be able to undo the bolt and drop them out the bottom? Or is there some tricky way i need to do this to replace the rubbers? Thanks Nick.
| Author: | Microwire [ Wed Sep 28, 2011 8:48 am ] |
| Post subject: | Re: Tierod Boot rubbers?? |
I usually have to put a bit of metal on top of the nut (a little bit smaller so you don't screw the thread) and wack the shit out of it with a hammer. Also there are spreader tools you can get too |
| Author: | joe5701 [ Wed Sep 28, 2011 9:22 am ] |
http://www.google.com.au/imgres?q=ball+ ... pVW&zoom=1 |
| Author: | Rusho [ Wed Sep 28, 2011 9:26 am ] |
Hit the side of the tie rod itself, they are a very tight tapered fit. The shock of hitting the side of them is usually enough to free them up |
| Author: | Fatzook [ Wed Sep 28, 2011 9:30 am ] |
Rusho wrote: Hit the side of the tie rod itself, they are a very tight tapered fit. The shock of hitting the side of them is usually enough to free them up
You mean hit the knuckle arm on the side where the tapered pin passes through |
| Author: | Rusho [ Wed Sep 28, 2011 9:31 am ] |
Fatzook wrote: Rusho wrote: Hit the side of the tie rod itself, they are a very tight tapered fit. The shock of hitting the side of them is usually enough to free them up You mean hit the knuckle arm on the side where the tapered pin passes through That's what I said |
| Author: | buzbox [ Wed Sep 28, 2011 1:10 pm ] |
I did mine the other day. http://www.auszookers.com/index.php?nam ... ht=tie+rod |
| Author: | Scrawny [ Wed Sep 28, 2011 6:17 pm ] |
Microwire wrote: I usually have to put a bit of metal on top of the nut (a little bit smaller so you don't screw the thread) and wack the shit out of it with a hammer.
Also there are spreader tools you can get too You'll stuff the ball joint if you do it this way. Hit the arm as Rusho suggested. Get a big hammer and pretend it just broke into your house and pinched all your stuff. |
| Author: | fordem [ Wed Sep 28, 2011 8:33 pm ] |
Either get a puller/separator - and please no "pickle forks" - or - get two hammers - place one on each side of the eye and then "clap" - or strike the knuckle on both sides simultaneously - this shocks the pin from taper. |
| Author: | Microwire [ Wed Sep 28, 2011 9:54 pm ] |
Scrawn wrote: Microwire wrote: I usually have to put a bit of metal on top of the nut (a little bit smaller so you don't screw the thread) and wack the shit out of it with a hammer. Also there are spreader tools you can get too You'll stuff the ball joint if you do it this way. Hit the arm as Rusho suggested. Get a big hammer and pretend it just broke into your house and pinched all your stuff. I don't see how it'd stuff the ball joint any more than hitting the arm? I would have thought it'd be better than hitting the arm because you will only have vertical movement, all your doing is hitting the part that's stuck not the part that's attached to it. |
| Author: | Scrawny [ Thu Sep 29, 2011 12:25 am ] |
You'll end up squashing/damaging the thread and nut. If you hit the arm it gives the right amount of shock in the right place to loosen the taper |
| Author: | Microwire [ Thu Sep 29, 2011 12:44 am ] |
That's why I use a piece of metal that is slightly smaller so you don't touch the thread. I take the nut off first too. Either way you'd get the wanted result. |
| Author: | Mubby [ Thu Sep 29, 2011 7:36 am ] |
Awesom thanks guys i think ill try the two hammer approach and get back to youse! |
| Author: | Mubby [ Sun Oct 02, 2011 4:56 am ] |
Thanks for your help guys, got them all out and changed over today!!!!!!! took about 1 hour to do six |
