It is currently Thu Oct 29, 2026 6:10 pm
Post Posted: Thu Sep 29, 2011 1:34 am
could this be done and would be be a good rear disk brake set up or should i only put these brakes on the front
Vehicle: '96 LWB trayback
Post Posted: Thu Sep 29, 2011 1:39 am
Why would you put bigger brakes in the rear than the front?
Of course, you could use LWB brakes at both ends. The gain would be minimal over using Lwb up front and stock fronts in the rear. You would also face the brake bias/balance issues that people running sierra discs in the rear get.
Post Posted: Thu Sep 29, 2011 1:42 am
running LWB at the front, wanting to put the same in the rear
running the prop vlve so the bias is all fixed
got a spare set or LWB vitara calipers and rotors and though rather then using little stock sierras on the rear i could use the LWB,
what do you think?
Post Posted: Thu Sep 29, 2011 8:32 am
It seems to me if you use a prop valve for the back, you are cutting the brakes down anyways. So that means you are not able to use all of the rear disks you have now without turning them down and loosing a percentage.
So while the LWB brakes may brake better, you won;t notice a difference because you will turn them down to match what you already have.
Where lwb brakes might make a difference is if you are carrying heavy loads and need stopping power for more weight. The weight will help keep the rear tires from skidding, so you could turn the prop valve down more, and use more brakes before they lock up.
Hope that makes sense
-Sky
Users browsing this forum: No registered users and 103 guests
