It is currently Fri Oct 16, 2026 1:38 am
Vehicle: 93 Sierra 2'' lift 30'' tires
Post Posted: Thu Sep 29, 2011 6:21 am
my transmission drain plug is completely stuck in there. Welded a bolt on, but the welds snap every time, put an easy out in there, still wouldnt budge at all. Heated it up, hit it with a hammer, tried using a chisel... i dont know what to do now... and i have a real mess of a plug down there now. :blink: could i angle grind the head off or something? Im really stuck on this one and its pissing me off because its the only reason i cant drive around... one little drain plug! :evil:
Cheers, Josh
Post Posted: Thu Sep 29, 2011 6:25 am
Try welding a nut on. Clean up the drain bung as best you can then weld in the hole of the nut. Make sure you get a good weld
Post Posted: Thu Sep 29, 2011 6:26 am
ive done that three times, they just keep coming off, but ill give her another go, its not the most spacious place down there ;)
Post Posted: Thu Sep 29, 2011 6:31 am
Can be done. If you have a grinder handy give it a quick clean up, that'll help the weld bite. What are you using to weld with? Don't be afraid to turn it up a bit
Post Posted: Thu Sep 29, 2011 6:33 am
alright, ill give it a good clean up and try again. im just using a ark and its on full amps haha, hopefully i can get this done!
Post Posted: Thu Sep 29, 2011 6:36 am
Otherwise just do what Steve does and just replace the whole box
Post Posted: Thu Sep 29, 2011 6:40 am
uh.. youre joking right?
Post Posted: Thu Sep 29, 2011 6:47 am
Have you got the fill plug out or checked it yet?
If that one is as stuck as the drain plug, leave the drain plug in until after you've got the fill plug undone... Its a pain trying to fill up the gearbox with oil via the gearstick hole ;)
I want my old sig back :(
Post Posted: Thu Sep 29, 2011 6:53 am
hahahaha! that would be a bit of a pain :D
yeah the fill plugs out and ready to be filled, just waiting to try and get the drain one out!
i just re welded a nut on, but the weld just snapped again. its like the drain plug has been welded on, no joke, its that tight. i cant think of any other options now! any ideas? haha, if i get any more angry ill just weld drill a hole in the plug and then weld it closed once its drained! :P
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Thu Sep 29, 2011 6:59 am
take it to your local exhuast or diff joint.. my local diff joint weled mine.. strong as only problem is that he put an imperial nut on :crazy:
Post Posted: Thu Sep 29, 2011 7:04 am
lol i had the same problem mate, had to use the biggest easy out i had then used a shifter with a piece of pipe over the end of it. even then it took a fuck load to get the bastard out. good luck.
cheers
chris
Post Posted: Thu Sep 29, 2011 7:08 am
alright, see the easy outs a great idea.. but me being a cheapo, welded a bolt onto it instead. Now the head of the bolt snapped off and i just have the shaft welded onto the plug :O i seem to making things worse and worse. guess thats what happens when youre a cheap bastard :D
Vehicle: 93 Sierra
Post Posted: Thu Sep 29, 2011 7:18 am
So the broken bolt shaft is solidly welded into the plug? If so can you drill out some angle or box section, slip it over the shaft, weld it on and use it as a lever?
Post Posted: Thu Sep 29, 2011 7:33 am
Mine was stuck too so I took the box out and emptied it.
And filled through the gearstick hole.
Post Posted: Thu Sep 29, 2011 7:37 am
Stick a nut over the broken shaft and fill the middle with weld. Don't weld the outside, just the inside. That way you can still get a socket on it
Post Posted: Thu Sep 29, 2011 7:43 am
yeah, tried the nut thing too, the weld just breaks and the nut comes off. mabye its my dodgey welding, i dont know, but it sure is giving me a hard time! cheers for the help guys.
sierra dan, yeah im thinking that might be the way to go!...
Post Posted: Thu Sep 29, 2011 7:46 am
Got to be your welder. Do you have access to a mig?
Post Posted: Thu Sep 29, 2011 7:50 am
yeah i do, reckon that would make much of a difference?
Post Posted: Thu Sep 29, 2011 8:02 am
Give it a try. I've had success doing it that way
Post Posted: Thu Sep 29, 2011 12:41 pm
Is there any galv coating on the nut? That could be half the issue for your weld breaking is the weld is not burning through the galv coating...
Vehicle: Yellow Ute
Post Posted: Thu Sep 29, 2011 12:57 pm
I guess you can't get two nuts on the broken shaft like a lock nut?
Post Posted: Thu Sep 29, 2011 1:25 pm
Get your hands on an aerosole product called 'nutcracker'. I used some today on some VERY rusty exhaust bolts, and they came off like they were brand new! 8)
And it will be FAR more effective to weld the nut onto the drain plug with a MIG. Its very hard to plug weld with a stick, as the slag cannot escape.
Post Posted: Thu Sep 29, 2011 3:29 pm
This happened to me on my gear box and diff for the diff I used easy outs came out perfect but for the gear box I mig welde a nut and role with the thread still in there. So I used same as fatzook nutcracker aswell as wd40. What I did first is heat the plug with a butane torch then use a chisel to loosen it up soak in nutcracker and wd40 and repeat took a while but worked
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Fri Sep 30, 2011 3:18 am
thanks for all your input guys, i ended up griding it back to the plug and buying a bigger, stronger easy out. it took a heck of a lot to get it out but it finally came. so relieved :) now my babys back on the road! woo :D
Post Posted: Fri Sep 30, 2011 4:02 am
yeah thats what i ended up doing, mine was stuck a beauty - got a massive easyout and used a breaker bar and a 10mm socket... bingo came out
Users browsing this forum: Google [Bot] and 255 guests
