| Rear wheel Noise http://auszookers.com/forum/viewtopic.php?f=5&t=26279 |
| Author: | sierra-morgs [ Fri Sep 30, 2011 8:49 am ] |
| Post subject: | Rear wheel Noise |
there is a really loud creaky sorta crackling sorta tapping noise coming from my back right wheel, i have checked the brakes and wheel nuts cannot figure out what it is. it gets louder and faster the faster you drive and almost sound like the wheels gonna come off sometimes. Any Ideas of what it could be maybe axle problem???? |
| Author: | Scrawny [ Fri Sep 30, 2011 8:51 am ] |
| Post subject: | Re: Rear wheel Noise |
Wheel bearing
| Author: | Microwire [ Fri Sep 30, 2011 9:13 am ] |
Scrawn wrote: Wheel bearing
![]() Haha yeah, i had the same thing recently, sounded like there was a rock caught in the drum brake or something turned out my bearing wasa knackered and dry as a bone, no grease at all. 9 hours later of cursing headscratching and blood the new wheel bearings were installed.
| Author: | sierra-morgs [ Tue Oct 04, 2011 9:30 am ] |
is it possible for diff oil to pass the wheel bearing and come out within the drum brake, because that looks like the problem? |
| Author: | christover1 [ Tue Oct 04, 2011 9:35 am ] |
sierra-morgs wrote: is it possible for diff oil to pass the wheel bearing and come out within the drum brake, because that looks like the problem?
Yes but that often is the result of stuffed wheel bearing, the wobbling stuffs the seal |
| Author: | alien [ Tue Oct 04, 2011 9:40 am ] |
^^ what he said, i've had this happen myself. |
| Author: | honks [ Tue Oct 04, 2011 9:53 am ] |
is there oil in the brake drum or on the bake of the brakes because it may also be leaking wheel cylinders on your brake but if your wheel bearings are stuffed it is probably the seals |
| Author: | 607CHA [ Tue Oct 04, 2011 6:25 pm ] |
Jack up the back and try and shake/wiggle the wheel left right up down if ya got movement replace em. Oh and do em both |
| Author: | sierra-morgs [ Tue Oct 04, 2011 9:03 pm ] |
honks wrote: is there oil in the brake drum or on the bake of the brakes because it may also be leaking wheel cylinders on your brake but if your wheel bearings are stuffed it is probably the seals
There is oil all through the drum brake its causing the brake pads to catch so now the brakes sound like they are grinding the whole time mainly on the one side, You can see the oil leaaking from the axel. The original clicking and tapping noise has actually gone |
| Author: | weaves [ Wed Oct 05, 2011 4:14 am ] |
sierra-morgs wrote: honks wrote: is there oil in the brake drum or on the bake of the brakes because it may also be leaking wheel cylinders on your brake but if your wheel bearings are stuffed it is probably the seals There is oil all through the drum brake its causing the brake pads to catch so now the brakes sound like they are grinding the whole time mainly on the one side, You can see the oil leaaking from the axel. The original clicking and tapping noise has actually gone The tapping noise would of been your bearing failing, and with it floggin around it destroys your seal, the oil goes through the bearing (which would of been why its stopped making spastic sounds as its now nice and lubricated) and into your drum. They aren't expensive to buy. Just a little annoying to fit. If you get stuck getting one or someones trying to rip you off email me at nathan.w@bearingdynamics.com.au ( WT are $50 a wheel, NT are $38 a wheel and overnight freight is $16.50) cheers weaves |
| Author: | sierra-morgs [ Thu Oct 06, 2011 2:41 am ] |
that sounds about right im gonna get the wheelbearings and the oil seals, replaced hopefully that will fix the problem, cheers for the help. |
| Author: | TryHard [ Thu Oct 06, 2011 3:48 am ] |
http://forum.difflock.com/viewtopic.php ... hlight=hub for the front |
