| Author |
Message |
Mike
lesspostingmorewheeling
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
 Posted: Fri Aug 01, 2008 2:22 am |
does anyone have pics of what they did with the brackets behind that crap plastic strip under the door of a sierra?
do people remove them or cover them up?
BlueSuzy
 Posted: Fri Aug 01, 2008 2:40 am |
The plastic mouldings...I kept losing the corner bits one by one
So i pulled them off, The Bracket doovas are spotwelded on, I drilled them off then covered them with a length of checkerplate, But 1st see if there is much rust
Mike
 Posted: Fri Aug 01, 2008 2:44 am |
they were packed with mud but no rust at all
is there any way of getting them off without drilling wholes in the car?
BlueSuzy
 Posted: Fri Aug 01, 2008 2:46 am |
Mike
 Posted: Fri Aug 01, 2008 2:47 am |
crap so no matter what its need a bit of body work once there off?
BlueSuzy
 Posted: Fri Aug 01, 2008 2:51 am |
Not if you grind them flush, Just clean the body after, Make sure there is no surface bubbles etc, And under coat , sand abit so smooth, then spray black.
Mine had warps and bubbles from the surface rust, so i scraped and wired brushed the rust, then sprayed the body panel, then put the checker on.
Mike
 Posted: Fri Aug 01, 2008 2:57 am |
how did you attach the checkerplate?
BlueSuzy
 Posted: Fri Aug 01, 2008 3:17 am |
When i finished drilling them off
When i finished the new plates
My rear plate
The side plates i started by putting them on with stainless countersunk bolts, But they wernt good enough to hold the plates onn as the threads were only into the sheetmetal  So i ended up screwing the end corners in to the body and sprayed them black. I also beaded some silicone under the plate to try and stop the rattles, if any . I tryed also to keep it neat, blacked out the screws but left the stainless.
My rear plate is countersunk bolts, stainless again but smaller, and there are nuts on the other side of the tailgate. No screws
I think this should be in fabrication now
Mike
 Posted: Fri Aug 01, 2008 3:26 am |
i like the back door thing
did you fill in the the holes you drilled?
i found some ready made checkerplate panels and i was thinking of just using sikaflex to stick them on
BlueSuzy
 Posted: Fri Aug 01, 2008 3:32 am |
The holes i just filled with silicone....Sikaflex may be ok, but i would screw them abit just incase they want to fall off  Depends how heavy they are too. Mine are steel...3mm thk
Mike
 Posted: Fri Aug 01, 2008 3:35 am |
the ones i looked at were alloy and they had a slight bend in them to fit the body they were $125 does that sound alright?
BlueSuzy
 Posted: Fri Aug 01, 2008 3:39 am |
If its for abit of bling, go alloy  Mine are abit of show and abit of armour...
What do you mean by bend? To go underneath abit?
For the price it sounds alright, But talkem down
MART
Joined: Thu Apr 26, 2007 11:30 pm Posts: 282 Location: Sydney
 Posted: Fri Aug 01, 2008 3:58 am |
Did the same thing , bunnings checker plate , pop rivets , no rust , too easy , if your going to silicone get a neutral silicone as most are acetic and will cause rust , Cheers Paul.
Mike
 Posted: Fri Aug 01, 2008 4:17 am |
BlueSuzy wrote: If its for abit of bling, go alloy  Mine are abit of show and abit of armour... What do you mean by bend? To go underneath abit? For the price it sounds alright, But talkem down
i can't remember off the top of my head but it either curves towards the bottom of the door a bit or like you said curves under the sill
it think i'd have to paint the black or maybe red
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Fri Aug 01, 2008 10:13 am |
ay Mike, I used a grinder and carefull ground away the spot welds that hold the bracket on. That way you don't need to drill holes through the spot welds in to the body. After that i cleaned up the surface with a flapper thing and painted it.
Pubic
 Posted: Fri Aug 01, 2008 10:55 am |
blues suzy.
if your worried about the thread tapping into your door, we can put NUTSERTS into your door. they are a little insert that crimps up on your sheetmetal door that have a thread inside them.
give me a buzz if you like and ill bring the bits and pieces home one arvo.
_________________ Web wheeler extroadinaire
basketcase
 Posted: Fri Aug 01, 2008 1:35 pm |
Some pics of mine I removed couple of weeks ago. I am yet to paint. Been a bit slack. Will just be painting the in matt black and putting some sliders there shortly.
BlueSuzy
 Posted: Fri Aug 01, 2008 8:34 pm |
Thats ok Pubic. The bolts seem to be holding in place, havent lost one yet...
Another little problem is the countersunk screws are too big so they bottom out on the 45angle b4 they tighten up
But i will leave them alone.
Pubic
 Posted: Fri Aug 01, 2008 10:15 pm |
thats because your screws are probably M6.. because of the larger dia head they need to be drilled deeper to sit flush. i could get you a couple of cup washers to suit, that way you will still have your countersunk screw but get a decent pull from the screw.
BlueSuzy
 Posted: Fri Aug 01, 2008 10:47 pm |
Try M12  but countersunk fully. It's ok dont worry
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Fri Aug 01, 2008 11:21 pm |
BlueSuzy wrote: Try M12  but countersunk fully. It's ok dont worry
Only M12!!!!! I hope you went high tensile!!!!!
M6 cap screws and nutserts would be the poo. And pop rivets for the povo's
_________________ SJ50.4.LYF
Pubic
:O are you serious.......
no wonder they bottom out! they're not screws theyre bolts!
Damo
 Posted: Fri Aug 01, 2008 11:29 pm |
Pubic wrote: :O are you serious.......
I think the steering box bolts are M12
BlueSuzy
 Posted: Fri Aug 01, 2008 11:33 pm |
The 4 shiney M12 stainless bolts aside are
Pubic
 Posted: Fri Aug 01, 2008 11:34 pm |
Damo wrote: Only M12!!!!! I hope you went high tensile!!!!! M6 cap screws and nutserts would be the poo. And pop rivets for the povo's
he should have just pinched some of the rivets from the syd harbour bridge....
MAYBE just MAYBE they would be strong enough
BlueSuzy
 Posted: Fri Aug 01, 2008 11:37 pm |
Nah, i think they are ONLY M10.  Yes overkill but i was making them to look good, Nothing boring, But abit of armour as well..
