It is currently Fri Oct 09, 2026 10:11 am
Post Posted: Sun Oct 02, 2011 6:43 am
do u have to take out diff centre to change pinion seal,,
or just "mark" the nut,pinion,diff and undo to put new seal in.
Post Posted: Sun Oct 02, 2011 6:48 am
To do it properly you need to replace the crush tube between the pinion bearings to reset the preload again.
Post Posted: Sun Oct 02, 2011 6:55 am
yeah thanks mate ,, was hoping to do the old mark it and check torque seting before i take it out..
geting a locker to go & bearing change in about a month, but being the rear seal im hoping to just drop a seal in for now as its pissing out on my exhaust.
is that doable?
Post Posted: Sun Oct 02, 2011 6:57 am
you might get away with it but you might find its leaking cause the bearings are flogged and the pinion is moving around stopping the seal from sealing
Post Posted: Sun Oct 02, 2011 6:58 am
Yep, that'll work. Just check the seal surface on the flange to make sure it's not damaged or grooved too much
...and what Royce said :lol:
Post Posted: Sun Oct 02, 2011 7:09 am
o.k thanks guys, il give it a go, but u may be right about the floged out bit,,
as iv had it for close to 2 years and done 3 (yes 3) trips brisbane to mackay and back nearly 1000ks each way. this is the first leak its had.
Users browsing this forum: Google [Bot] and 217 guests
