It is currently Sat Oct 10, 2026 2:44 am
Post Posted: Mon Oct 03, 2011 10:46 am
hi guys. just need some quick info.
where abouts does the earth cable go to that hooks onto the battery?
and on the starter motor which cable goes to what terminal. there is a thick wire and a thin wire.
Post Posted: Mon Oct 03, 2011 10:51 am
Earth cable to starter body.
Thick positive lead to starter solenoid threaded terminal.
Thin wire to small spade connector on solenoid
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Mon Oct 03, 2011 11:15 am
i have 2 threaded terminals on the starter motor. and a thick wire with ring terminal and a thin wire with ring terminal and also the spade terminal wire
so the earth cable doesnt go on the terminals on the starter motor? do i put it on one of the bolts that holds the starter motor to the gearbox? or is ther another bit on the starter motor body? cant remember after i pulled it all off lol
Vehicle: '99 Jimny
Post Posted: Mon Oct 03, 2011 11:23 am
Earth cable does not go onto one of the terminals on the starter. Should just go on one of the mounting bolts.
The two ring terminals should go on the terminal further away from the main starter body. Only the wire that goes from the solenoid straight into the starter should go on the other one.
The spade terminal just goes on the spade fitting on the solenoid.
For example, the ring terminals should go on the top terminal in this pic.
Post Posted: Mon Oct 03, 2011 11:26 am
ok thanks guys. its pretty late but think il go down to the garage again. lols
Post Posted: Mon Oct 03, 2011 12:34 pm
that is correct like that.
now i discover that one of the sparkplug holes in my rebuilt head isnt good. plug wont go in past like 1.5 threads. the rest are ok :(
Users browsing this forum: No registered users and 210 guests
