It is currently Sat Oct 10, 2026 9:39 am
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2  Next
Post Posted: Tue Oct 04, 2011 12:07 pm
hey guys got a 92 swb sierra currently has 2 inch body lift and 2 inch susp lift with 31s. been looking at this 3/4 elliptical rear setup on a few forums and just wondering why it isnt used as often as i would ov thought. seems like a good idea to get a bit extra flex and was thinking of giving it a go. any one have any opinions on this setup?
Post Posted: Tue Oct 04, 2011 12:14 pm
mostly cos its illegal, like, noticably so... MrRocky on here had a 3/4 rear which worked really well and was predicatable, i saw it in action a fair few times and it went great. He'd designed his with a pin to keep the top leaf pinned to the chassis for road use so it wouldnt flop around.
Post Posted: Tue Oct 04, 2011 8:30 pm
It can inherit a "pig rooting" type of action on steep uphill climbs. I know gwagonsteve has built buggies like this, and mentioned this. Your fuel filler will also be in the way....
I'm hoping to build this soonish :D
Vehicle: 2018 DMAX
Post Posted: Tue Oct 04, 2011 8:58 pm
Its a pretty easy and cheap way of getting rear flex. And as far as im concerned, from behind on road it looks stock. Axel wrap is something to consider, you will want heavy rear springs and possibly a traction bar. This will come down to tyre size, gearing and so on. With small tyres and stock gearing, a heavy set of springs work well.
One thing to think about, how are you going to get the front operating to match the rear? Gwagensteve had a good post about this awhile ago, mite be worth checking out...
Post Posted: Wed Oct 05, 2011 10:00 am
will it lift the rear a bit?
Post Posted: Wed Oct 05, 2011 10:05 am
n0
Post Posted: Mon Nov 07, 2011 3:17 pm
THINKING BEFORE POSTING!!!
Post Posted: Tue Nov 08, 2011 6:39 am
Just remember,
it is harder to achieve on a WT Sierra,
because springs are out side of chassis,
whereas NT springs are in line with chassis
Vehicle: 2018 DMAX
Post Posted: Tue Nov 08, 2011 7:24 am
christover1 wrote:
Just remember,
NT would be the ducks nuts to do a 3/4 on... Cut the chassis mount off, two square U bolts and some form of locking notch around the u bolt area and your done.. Under an hour a side...
Post Posted: Tue Nov 08, 2011 7:45 am
i used a bit of angle on my w/t
made it piss easy set it up and did the whole thing on the bench and
welded it on in 5 mins, moving the fuel tank though took a little longer.
i had mine pinned for road use so it wasnt noticeable, i also inverted the shocks to make the most out of the extra travel.
if i did it again i would use a longer leaf
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Tue Nov 08, 2011 8:21 am
SSSIERA wrote:
lol it gets funny the longer you stare at it. me likey :lol:
Post Posted: Tue Nov 08, 2011 9:12 am
Would this work with a nt. With WT diffs so that it is still on narrow track spacing. Then inboard the springs to gain awesome flex. Then almost the only way to get the front to match would be to use lifted rears in a RUF setup. Does this sounds okay? Or is there something im missing?
Post Posted: Tue Nov 08, 2011 9:19 am
what is the upper spring from? getting ideas!haha
back in a built sierra!
Post Posted: Tue Nov 08, 2011 9:25 am
upper spring is just a rear sierra spring, a hilux rear would be better i think
Post Posted: Tue Nov 08, 2011 3:25 pm
please keep in mind that this idear is just in my head, i havent sat down and thought out the technicalitys.
but i will be looking into a way of making this a bolt on of sort of deal. to maintain legality (reduce un wanted attention). basicaly i wanna use a sierra front spring on the top. and 4wd trailer shackles on the back.
there V shaped and have 3 pins in them. middle pin goes to were the normal shackle would mount to the chasis, bottom pin goes to the bottom spring, top pin goes to the top spring. round town center pin stays in. hit the dirt. pull the two center pins and away you go. only problem i can see so far is that the top spring will need to be shorter than the bottom spring.
MIGHT even be able to get it engineered this way????
also i know a guy ...LOL
who has invented an air oporated, cab controlled sway bar detachera.
but he is a bit of a nutter and wont market/ share his thing with anyone else. very very clever guy but. trying to get the plans for it, but not having much success.
Post Posted: Tue Nov 08, 2011 4:51 pm
Good luck..
Post Posted: Tue Nov 08, 2011 9:39 pm
Remember what I said about thinking more and speaking less?
A) the retaining pin idea has already been covered by mr rocky
B) the original rear spring hanger where the shackle attaches to the chassis is removed
Post Posted: Wed Nov 09, 2011 8:30 am
Vehicle: 2018 DMAX
Post Posted: Wed Nov 09, 2011 8:43 am
:rofl: :rofl: :rofl:
ssisera, i think your making a simple idea far to complicated... From behind even without mud flaps and a rear bar to hide everything its not possible to notice its there on mine.. The top spring should sit flat until you flex it..
Also what the fuck does a "air oporated, cab controlled sway bar detachera." have to do with anything? and I doubt your mate invented it since its an item that has been available for some time :roll: Maybe listen to peoples advise when they say speak less.. Or are you not capable of going 5 minutes without posting utter dribble and annoying the piss out of every cunt on here?
Post Posted: Wed Nov 09, 2011 9:33 am
not talking about a retaining pin im talking about a fully removabel top half.
by using a shorter top spring rather than a longer one, should be able to keep the spring hanger.
seems to be a matter of opinion, and the first thing coppers look at when looking to sticker a car is the tyres and how much tread they have.
thats what the sway bar detachera is about.
have you ever heard the saying, "a man can be judged by the size of the things that annoy him"?
also there is no need to degrade yourself, (along with everyone esle associated with auszookers) by swearing like that, its uncalled for.
hope that i have been able to answere you questions
Yours sincerely
SSSIERA
Post Posted: Wed Nov 09, 2011 9:35 am
hahaha
:rofl:
Post Posted: Wed Nov 09, 2011 9:52 am
There is no point having a shorter top spring, mrrocky has done it and said the same thing, gotta go longer next time
Post Posted: Wed Nov 09, 2011 9:57 am
except for being able to do it legaly, not voiding insurance and not getting yellow stickers!
at the cost of slightly less flex? witch could be regained by getting a custom spring made that is softer.
and from the look of mr rockys picture bellow he didnt use a shorter spring he used a longer one but would have gone even longer if he did it again.
Vehicle: Zookless
Post Posted: Wed Nov 09, 2011 10:07 am
You just don't get it do you...
Any non-approved modifications to suspension are illegal. Just because you put a pin in there doesn't mean diddly-squat when it comes to legalities and insurance. :roll:
Post Posted: Wed Nov 09, 2011 10:12 am
and i doubt he'll ever get it either. :lol:
Post Posted: Wed Nov 09, 2011 10:13 am
I never get it either.
But thats understandable :)
Post Posted: Wed Nov 09, 2011 10:28 am
ill do a quick drawing. i mean a fully bolt of top spring, that u put back on b4 u go 4wding, then unleash it when u get ofroad
Post Posted: Wed Nov 09, 2011 11:00 am
MrRocky wrote:
A 3/4 elliptical setup is not legal - neither is driving without a license but hey thats another story hey- but if you think its cool then go for it
Post Posted: Wed Nov 09, 2011 11:01 am
Ugh dude seriously...........
3/4 elliptical is the last thing you need to do on your vehicle, just drop it and chill.
Hey boosted, MrRocky
Both you guys don't run track bars? How much axle hop do you get when the rear is flexed out and underload?
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Nov 09, 2011 11:08 am
and unless you have the time to play around with it, it wont perform as well as it should, ours is pretty poor
Users browsing this forum: No registered users and 279 guests
