It is currently Tue Sep 22, 2026 7:40 am
Post Posted: Tue Oct 04, 2011 6:56 pm
Just wondering if all my g13ba manifolds and extractors will bolt up to a b16a i am considering a transplant but don t have a heap of money for efi and my motor is nearly stuffed.
Post Posted: Tue Oct 04, 2011 6:59 pm
cos the G16 block is taller i think with the extractors you run into trouble, but my understanding is that the heads would be the same just with larger valves so i dont see why the intake wouldnt work
Vehicle: 02 jimny
Post Posted: Tue Oct 04, 2011 7:38 pm
Mine bolted straight up.
LIVING LIFE ON THE EDGE, TILL YA ROLL
Post Posted: Tue Oct 04, 2011 7:42 pm
The inlet bolts up but it needs a bit of attention with a porting tool to get the ports to match up reasonably well, the stock carb is also quite restrictive.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Tue Oct 04, 2011 8:11 pm
manifolds bolt up however ya might have some clearance issues with the inlet
and fuel pump.
i also used a sierra carby on a g16a and it worked fine.
Post Posted: Wed Oct 05, 2011 1:56 am
i found out that i can get a low km import g16a with all manifolds, carby etc. all i need is my starter and alternator for $1250 does that sound like a good price ?
Post Posted: Wed Oct 05, 2011 4:41 am
Almost worth getting a g16b conversion!
Post Posted: Wed Oct 05, 2011 7:11 am
I want to do a quick conversion not re wiring and changing fuel systems and all that stuff besides i need my car 2 days a week to get to night study at uni so i can t afford to have my car sitting around while i try and sort out wiring problems
Users browsing this forum: No registered users and 180 guests
