It is currently Tue Sep 22, 2026 4:37 am
Post Posted: Tue Oct 04, 2011 11:51 pm
Hey guys
I'm changing the v6 out and puting a g16b in
Can anyone tell me if it is possible to just simply take the input shaft from the g16b box and put it in the h20a box
Post Posted: Wed Oct 05, 2011 12:12 am
The G16b box will be completely different to the h20a.
Why not put in a h27?
Post Posted: Wed Oct 05, 2011 12:30 am
They look almost identical
The only difference I can c is the input shaft and the bolt pattern to bolt up to the motor
Almost positive the bolt pattern on the box end is the same
And a 2.7 will be too heavy and having no room in the engine bay will be a problem FOR WHAT I WANT
And will be a slug compared to my 1.6
Post Posted: Wed Oct 05, 2011 5:23 am
I'd look at the J20.........
Post Posted: Wed Oct 05, 2011 5:25 am
When Steve did his (was an early import engine) there was mention of it being a 1.6 box in it and used a different clutch to our H20's
but if you have an input shaft and bellhousing dont you have the rest of the box to use?
Post Posted: Wed Oct 05, 2011 8:13 am
Yeah I do but the bloke I bough the LWB with the h20 off said that he had the box rebuilt
Not that that means much but the box and clutch fork are very clean
So I thought I might just leave the box in there and use it
Only problem is the input shaft is about 2 inches longer on the v6
Does steve have a thread that I could read through
Users browsing this forum: Bing [Bot] and 196 guests
