It is currently Tue Sep 22, 2026 8:12 pm
Post Posted: Wed Oct 05, 2011 10:20 pm
so i got up early to go fishing pull onto the free way and i have a bad missfire under load :evil:
97 g16b 3 wire af meter
where is the diagnostic plug? and which to pinouts do i short out? for codes.
no check engine light on dash.
changed plugs no difference
removing leads one at a time causes rougher running
as does doing the same with injectors so fuel and spark appear ok
dont have a compression tester handy but i doubt it would of just burnt a valve for no reason.
cheers peeps.
Post Posted: Wed Oct 05, 2011 10:27 pm
How did you remove the leads and injector plugs when the engine was misfiring under load.....
Lil Foot!
Post Posted: Wed Oct 05, 2011 10:34 pm
done at idle but vehicle is slightly missing at idle also
Post Posted: Wed Oct 05, 2011 10:36 pm
Misfire under load suggests to me a spark problem.
I would be looking hard at plugs, leads, dissy cap & rotor button.
Post Posted: Wed Oct 05, 2011 10:41 pm
Do what Jas has suggested first. No need to go all balls in and start with the more complicated stuff
Lil Foot!
Post Posted: Wed Oct 05, 2011 10:44 pm
Wait til its night (dark) and watch for arcing on the leads. normally happends as you increase revs a bit.
Post Posted: Wed Oct 05, 2011 11:08 pm
dist cap looks pretty worn out, will replace this and leads and see how we go. cheers guys
Post Posted: Wed Oct 05, 2011 11:31 pm
one other question, does the rotor button just pull out?
Post Posted: Thu Oct 06, 2011 12:05 am
yes
Lil Foot!
Users browsing this forum: Google [Bot] and 188 guests
