It is currently Sat Aug 01, 2026 8:10 pm
Post Posted: Thu Oct 06, 2011 9:20 pm
hi all l have an absolute stock 1990 suzuki vitara jlx l want to build it up with a custom bullbar which l am building a 2 inch body and suspension lift(or am considering the calmini 6 inch combo would like info on that if anyone could help), fog lights, dual batterys,
now l know when l lift it l can fit the maxxis bighorn 31x10.5 but l am curious is it possible to fit the 33x12.5 with out trimming can anyone help?
Vehicle: LWB Sierra & XL7
Post Posted: Fri Oct 07, 2011 5:57 am
I have the 3" Calmini and 2 " body with 31 Bighorns on -23 offset rims.
they fit just fine but I've since found out that some very light massaging will be required to clear them when it's all flexed up and when reversing on full lock.
With 6" lift, well personally I don't see a need for that but yes you would be able to fit 33's
'92 Vitara & Camper trailer
Post Posted: Fri Oct 07, 2011 6:05 am
I think you'll find that the width & offset will be the biggest issue with the 12.5" wide 33" tyre, calmini do suggest something along the lines of a 32x9.5 or 33x9.5, but high & low range gearing will need to be addressed.
Post Posted: Fri Oct 07, 2011 7:05 am
Not going to fit much with out a bit of trimming 2 guys in my club run 33 bf with 3 in body lifts. ones a 2 door ones a 4 door
Any rim with a neg off set will make it hard to fit any thing bigger with out lots of trimming because the larger scrubradius makes ur tires hit the fire wall
235 on 0 offset rims just touched my firewall when turned on my car when I got it
U can push ur wheel base out which helps heaps
Post Posted: Fri Oct 07, 2011 7:56 am
i have 33x12.5 on mine and i just bolted them on, didnt have to do anything except
give the rear wheel arch a bit of a hit with a air chisel.
Post Posted: Fri Oct 07, 2011 7:58 am
but, the previous owner did a fair bit of chopping to get his 32's to clear. :wink:
Post Posted: Fri Oct 07, 2011 8:03 am
haha maybe. :wink:
Post Posted: Fri Oct 07, 2011 1:49 pm
After my lift l think l will just stick with the 31x10.5
1990 suzuki vitara stock with big plans
Users browsing this forum: No registered users and 364 guests
