It is currently Thu Sep 24, 2026 8:12 pm
Post Posted: Thu Oct 06, 2011 11:24 pm
I am getting ready to remove the Vitara engine.
Is the high pressure fuel line still under pressure when parked?
Or do I have to be careful not to get a face full of fuel?
If it is under pressure, is there a relief valve or similar,
before I disconnect hose fittings.
cheers
christover
Post Posted: Thu Oct 06, 2011 11:29 pm
Just pull the fuel pump fuse and wind it over for a few seconds to relieve any pressure before you pull it apart
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Thu Oct 06, 2011 11:30 pm
when i helped a mate do his HG we just undid the clamps off the rail, there was a bit of fuel that leaked out and was under a bit of pressure but nothing extreme
Go hard,
Post Posted: Thu Oct 06, 2011 11:31 pm
if ur unsure wrap a rag around it!
THINKING BEFORE POSTING!!!
good thinking, but I have too much undone to try that. :oops:
Post Posted: Thu Oct 06, 2011 11:33 pm
thanks all, will be careful, and have eyes closed while I undo it
Vehicle: 4wd
Crack it at the pump and leave it for 5 minutes.
Watch out or you'll get sued.
Post Posted: Thu Oct 06, 2011 11:34 pm
Theres a large plug/bolt type thing on end of the rail,
may be that could relieve it,
before getting under tha car.
Post Posted: Thu Oct 06, 2011 11:41 pm
yep the bolt at the front, put your spanner on it, cover with a rag and undo it, a rails worth of fuel will drain out
if it hasnt run for a few days I doubt any pressure is still there but it pays to be careful and wear glasses
Post Posted: Thu Oct 06, 2011 11:45 pm
Many thanks,
much better than lying under car trying to undo lines with eyes closed.
My eyes are the only thing left that still works properly,
so will be looking after them.
Post Posted: Fri Oct 07, 2011 12:41 am
Don't forget to keep ya mouth closed too. :wink:
SS
Post Posted: Fri Oct 07, 2011 12:46 am
I often get told that :D
Post Posted: Fri Oct 07, 2011 2:36 am
Only a dribbled out, so thats was good.
But now I can't undo the bloody line, stupid rusty dirty couplings.
Will spray and leave it till another day.
Users browsing this forum: No registered users and 155 guests
