It is currently Sat Sep 26, 2026 4:37 am
Post Posted: Fri Oct 07, 2011 5:17 am
G'Day,
Ordered 235x75 15's for my jimny. Expect them to arrive next week sometime.
The rims are dynamic 15x7's with -12 offset.
Have TD 80mm spring/shocks, ARB bar and removed sway bar.
What do I expect to trim/cut/grind to make them fit ?
Guy
Better than stock...but not by much.
 Profile YIM
Post Posted: Fri Oct 07, 2011 5:43 am
drewmouli wrote:
I took about 15mm off both sides of my ARB bar to stop them rubbing, the guards still rub a bit but if you get the jimny bits radius arms itle stop it from happening.
That's pretty much it. Likewise for the ORA radius arms. Moves the axle forward by about 20mm
Post Posted: Fri Oct 07, 2011 6:19 am
8O How dose the drag link not hit the panhard rod? :?
Might have to get my some of those arms of they move the diff forward 20mm..
Also here;s that other thread i was talking about... http://www.auszookers.com/index.php?nam ... ic&t=26459
Post Posted: Fri Oct 07, 2011 6:32 am
Axle is back close to it's original stocko position. All seems to be well thought out.
Post Posted: Fri Oct 07, 2011 6:43 am
What size do you get ? 3" Radius arm full vehicle set ? (445 pound)
 Profile YIM
Post Posted: Fri Oct 07, 2011 6:49 am
I just bought the front pair and they are 4.5" lift version. I didn't feel that the rears were necessary but now that I've felt the difference in my front spring behaviour (they are now straight up instead of curved and only really using one side of the spring) I may eventually get some rears.
Post Posted: Fri Oct 07, 2011 6:50 am
Did you buy your's from ORA Mr nutter? I need some new arms, mine are farked 8O
Post Posted: Fri Oct 07, 2011 6:51 am
check pictures of front guard chop in my build thread
http://auszookers.com/index.php?name=Fo ... &start=150
still get slight rubbing up inside the guard and on edge of plastic flare, nothing serious though
Users browsing this forum: No registered users and 441 guests
