| transfer http://auszookers.com/forum/viewtopic.php?f=5&t=26545 |
| Author: | mud-skippa [ Fri Oct 07, 2011 9:18 pm ] |
| Post subject: | transfer |
hey guys just wondering if a transfer from a w/t will fit in a n/t thanks jarrad |
| Author: | 607CHA [ Fri Oct 07, 2011 9:22 pm ] |
| Post subject: | Re: transfer |
I think you'd have to change the flanges? But people 1ltr transfer in 1.3. So I don't see why not. I could be wrong |
| Author: | Rusho [ Fri Oct 07, 2011 9:26 pm ] |
607CHA wrote: I think you'd have to change the flanges? But people 1ltr transfer in 1.3. So I don't see why not. I could be wrong
Spot on mate |
| Author: | weaves [ Fri Oct 07, 2011 9:28 pm ] |
Plus your NT will most likely have the handbrake on the back of it. |
| Author: | Jackson [ Fri Oct 07, 2011 9:30 pm ] |
If it is the NT without a 4x4 switch is it you can't put transfer gears in it but your can swap the flanges or you can't do both? |
| Author: | 89_tintop [ Fri Oct 07, 2011 9:41 pm ] |
Jackson wrote: If it is the NT without a 4x4 switch is it you can't put transfer gears in it but your can swap the flanges or you can't do both?
You cant do both.. To make it work you have to run a modified shafts |
| Author: | foolsp33d [ Fri Oct 07, 2011 10:00 pm ] |
modified being a NT/WT shaft, but with the 1.0(smaller PCD-non swithced) flange at the xfer end. the switched 1.0 xfer off memory will use the standard NT flange... that makes sense right!? |
| Author: | 89_tintop [ Sat Oct 08, 2011 1:25 am ] |
Yeh ... Makes sense to me ... |
