| Throttle body - what's this bit about http://auszookers.com/forum/viewtopic.php?f=5&t=26584 |
| Author: | Che [ Sun Oct 09, 2011 8:29 am ] |
| Post subject: | Throttle body - what's this bit about |
I got a throttle body i'll eventually pop on top of my LPG setup, just wondering what this bypass bit is all about. Is this an idle flow bypass or is it a feed to go to some sensor? Hopefully the green arrows are dark enough to make sense of
| Author: | royce [ Sun Oct 09, 2011 8:32 am ] |
| Post subject: | Re: Throttle body - what's this bit about |
yes |
| Author: | JrZook [ Sun Oct 09, 2011 8:32 am ] |
That would go to the idle up air bypass solenoid. Block it off when you mount it. SHouldn't have any issues |
| Author: | Che [ Sun Oct 09, 2011 8:38 am ] |
OK cool, I have the adaptor plate made, was just wondering if I need to get the dremel out and accomodate for this. So the throttle butterfly is supposed to sit slightly open at rest to allow for an idle flow? |
| Author: | steak_knife [ Sun Oct 09, 2011 8:39 am ] |
che_guitarra wrote: OK cool, I have the adaptor plate made, was just wondering if I need to get the dremel out and accomodate for this.
So the throttle butterfly is supposed to sit slightly open at rest to allow for an idle flow? yes.... |
| Author: | JrZook [ Sun Oct 09, 2011 8:41 am ] |
If it has the bypass blocked off then yes it will need to be slightly open. Fab up a throttle stop so you can adjust your idle speed. |
| Author: | Che [ Sun Oct 09, 2011 8:42 am ] |
It's got an adjuster screw already, but as it's set the butterfly is 100% closed at rest. Easy fix, cheers guys |
| Author: | 11_evl [ Sun Oct 09, 2011 6:31 pm ] |
butterfly should sit slightly open so it doesnt jam or give a stiff feel when opening |
