http://auszookers.com/forum/
what should i get for my zook next?
http://auszookers.com/forum/viewtopic.php?f=5&t=26601
Page 1 of 2
Author:  Aaron [ Mon Oct 10, 2011 1:18 am ]
Post subject:  what should i get for my zook next?
As the title suggests what should I get for my zoom next?
1: 6.5's
2. Air locker
Or get fatzook to do a ruf
I have about $1600 to spend
Author:  JrZook [ Mon Oct 10, 2011 1:28 am ]
Post subject:  Re: what should i get for my zook next?
What do you have already? Where do you wheel?
Author:  shakes [ Mon Oct 10, 2011 1:38 am ]
What size tires? are you running/will you run?
Do you have bar/winch/uhf?
Either way, I'd say a locker last
Author:  rpmwrx [ Mon Oct 10, 2011 1:54 am ]
I would say gearing... It will totally transform your zook driving experience!
Author:  Aaron [ Mon Oct 10, 2011 4:53 am ]
I drive lots if big water washouts and ruts/ rocky steep hill climbs I have 30in bighorns and a 2 inch lift I've got an Arb bar but its rooted and a uhf
Author:  alexvitara [ Mon Oct 10, 2011 5:42 am ]
wheel it Armsup
Author:  dank [ Mon Oct 10, 2011 6:02 am ]
I'd say reduction gears. best bang for buck mod you can do. Once you've got the hang of that then go a locker. RUF is not a bad idea but definitely the other two first.
Author:  Ben_Sierra [ Mon Oct 10, 2011 6:11 am ]
If you've got 30s then definitely gears!
You'd be amazed at the improvment both off and on road!
Author:  MrRocky [ Mon Oct 10, 2011 6:19 am ]
gears are useless without a locker, just get a front lockrite and save for gears
Author:  zammit [ Mon Oct 10, 2011 7:55 am ]
:crazy:
Author:  MrRocky [ Mon Oct 10, 2011 7:58 am ]
yeah what would i know right :crazy:
ever driven an unlocked geared car on 30's ? they suck balls
Author:  just_cruizin [ Mon Oct 10, 2011 8:00 am ]
No offense but just means you can't pick lines. Gears give the best overall benefit after "good" tyres. Lockers aren't required for 90% of the tracks given good wheel placement.
Author:  MrRocky [ Mon Oct 10, 2011 8:01 am ]
maybe the tracks u drive
Author:  shakes [ Mon Oct 10, 2011 8:07 am ]
Some more info on 'what' you drive would be nice rather than a blanket statement.
Gears will make your car easier to drive in all conditions.
A locker will usually get you further into the poo and not having one will teach you how much getting crossed up sucks. I will also second that good wheel placement will get you as far as someone with lockers that 'just pins it' then when you can afford them you will leave them for dead.
I'll vote gears - or winch/bullbar as that will help get you out ;)
Author:  MrRocky [ Mon Oct 10, 2011 8:16 am ]
in sand i assure u that a unlocked ungeared sierra on 30's will drive everything better than a geared one on the same tyres.
Author:  zooky08 [ Mon Oct 10, 2011 8:18 am ]
You can get both a rear locker and 6.5s for $1600 :lol:
Author:  Mattmorgo [ Mon Oct 10, 2011 8:19 am ]
in qld (where op is from) were lucky enough to have more then just sand available, and you cant beat the control you have with gears when driving steep inclines and declines, Or when driving rocks
Author:  Jackson [ Mon Oct 10, 2011 8:19 am ]
I am interested in this too. My zook is a stocker and I took it out the other day and found there was a couple of quite specific bits, mainly steps as the spring hanger just plowed into them before the wheel could get anywhere near the step.
I tried a couple of different lines and approches, It probably doesn't help I am a new dero driver :lol: but I couldn't see me getting up it.
Did most of you fellas chuck some lift in first?
Author:  MrRocky [ Mon Oct 10, 2011 8:36 am ]
i drive big water washouts and ruts/ rocky steep hill climbs
Author:  sleeperzook [ Mon Oct 10, 2011 8:37 am ]
I'd do this. Honestly I can see where MrRocky is coming from with his comments. There is no substitute for proper wheel placement but in my experience of all types of terrain (sand, mud, rock) sometimes the only way up is straight through a massive rut that will max out your flex, lift wheels and have you stuck with open diffs. The question you have to ask is do you need to get up there or just want to get up there? If its a case of 'have to' then the only option is to smash it, which is where a locker is gold, but coupled with gears makes a zook crazy capable.
In the end drive I'd say gear it, to be nice on your clutch and zook, then once you find yourself getting stuck again, lock it.....air if you got the $$$
Author:  steak_knife [ Mon Oct 10, 2011 8:45 am ]
:helloo: subwoofer!!!!
Author:  zooky08 [ Mon Oct 10, 2011 8:54 am ]
Smelly tree for your revision mirror :D
Author:  607CHA [ Mon Oct 10, 2011 9:02 am ]
fuel tank lift.
Author:  worldo [ Mon Oct 10, 2011 9:10 am ]
http://www.ebay.com.au/itm/EXHAUST-MUFF ... 3f0ec9a6ce
defently one of these.
Author:  just_cruizin [ Mon Oct 10, 2011 9:27 am ]
Most of my wheeling these days is through stuff that has never been driven. Even when unlocked we were going through stuff most wouldnt consider.
As I said a good driver unlocked will out do a average driver with lockers. Anybody can point and shoot, it takes skill to drive the line.
Mods - gears and get Pete to ruf you up, don't forget to budget for brake hoses and shocks (don't forget to trim the bump stop mounts)
Author:  whincup [ Mon Oct 10, 2011 9:58 am ]
doof doof!! :woohoo:
Author:  JrZook [ Mon Oct 10, 2011 9:59 am ]
OI speak for yourself!! lil foot is unlocked, geared and on 30's and still straight!
Although she takes more time than the locked rigs she still goes quite a few places! :D
Lockers and 30's on any moderately hilly terrain calls for entertaining, bounce into everything, smoke that clutch type of driving.
Author:  just_cruizin [ Mon Oct 10, 2011 10:05 am ]
unlocked vehicles
http://www.youtube.com/watch?v=xkntqsB7tkA
1 year later locked
http://www.youtube.com/watch?v=oc0r4sdgYsc
without gears a zook won't drive either locked or not.
Author:  larry [ Tue Oct 11, 2011 12:23 am ]
i like this thread
what should I do to my zook next (lwb vit)
i have 215s and 50mm spring lift and i have to keep it legal
should i get:
- tyres, for offroad only (235 or 30s)
- rear spool or lockright
- front spool/ lockright (on alloy diff)
- other ideas?
i would like to spend 500 or less
Author:  Gwagensteve [ Tue Oct 11, 2011 5:59 am ]
Larry, if you want to stay 100% legal, the only thing on your list you can do is the front lock wrong. (which I wouldn't do with an alloy front diff) AFAIK, lock rights aren't actually legal for road use although they are difficult to detect.
You definitely don't want to spool the rear in a daily driven vitara.
You don't want a spool in the front of anything, especially an alloy diff vitara.
You won't get bigger tyres on rims for your budget, and you might not like what the will do to your gearing off road.
I would lock the rear in your position though- it's the biggest bang for your buck mod you can do.
Steve
Page 1 of 2 All times are UTC + 9:30 hours
