| engine fan http://auszookers.com/forum/viewtopic.php?f=5&t=26657 |
| Author: | Bennyzarb [ Tue Oct 11, 2011 2:47 am ] |
| Post subject: | engine fan |
Will a vitara clutched engine fan (viscous fan) fit strait on a 1.3 sierra engine and is there much modification to make it fit advantages and disadvantages plz |
| Author: | Bennyzarb [ Tue Oct 11, 2011 5:40 am ] |
| Post subject: | Re: engine fan |
And can I run my 1.3 shroud |
| Author: | stockman [ Tue Oct 11, 2011 5:42 am ] |
Someone like gwagon will be able to fill you in. But I believe it will fit and that you can use the shroud. And its win win. |
| Author: | Gwagensteve [ Tue Oct 11, 2011 6:03 am ] |
Yes and sort of. It is a 100% bolt on. It might brush your fan shroud, so you might want to modify the shroud a little. I've only ever fitted them to non-1.3 sierras (1.6's and 660) but I reckon with a 1.3 it might actually just clear the shroud with no mods. It's the single biggest cooling upgrade you can do to a sierra. It's such a cheap, easy and effective modification. Steve |
| Author: | Bennyzarb [ Tue Oct 11, 2011 6:10 am ] |
Ahh ok thanks how much am I looking around and if I do need to adjust the shroud how will I go at it |
| Author: | Bennyzarb [ Tue Oct 11, 2011 6:13 am ] |
I am looking at doing the el alternator upgrade this weekend along with a vitara fan and maby a thermo |
| Author: | Gwagensteve [ Tue Oct 11, 2011 6:19 am ] |
Bennyzarb wrote: Ahh ok thanks how much am I looking around and if I do need to adjust the shroud how will I go at it
A bit of heat, maybe a strip of thin aluminum to open it up a bit- whatever works. Just don't cut the shroud away, it defeats the purpose. Steve. |
| Author: | steak_knife [ Tue Oct 11, 2011 6:27 am ] |
Gwagensteve wrote: Yes and sort of.
It is a 100% bolt on. It might brush your fan shroud, so you might want to modify the shroud a little. I've only ever fitted them to non-1.3 sierras (1.6's and 660) but I reckon with a 1.3 it might actually just clear the shroud with no mods. It's the single biggest cooling upgrade you can do to a sierra. It's such a cheap, easy and effective modification. Steve I'm liking you lately Mr G.... |
| Author: | zuk85 [ Tue Oct 11, 2011 6:36 am ] |
steak_knife wrote: Gwagensteve wrote: Yes and sort of. It is a 100% bolt on. It might brush your fan shroud, so you might want to modify the shroud a little. I've only ever fitted them to non-1.3 sierras (1.6's and 660) but I reckon with a 1.3 it might actually just clear the shroud with no mods. It's the single biggest cooling upgrade you can do to a sierra. It's such a cheap, easy and effective modification. Steve I'm liking you lately Mr G.... sounds like a proposal could be on the way soon aye |
| Author: | steak_knife [ Tue Oct 11, 2011 6:42 am ] |
I propose Mr G build's a car that's not ugly!!! |
| Author: | Bennyzarb [ Tue Oct 11, 2011 10:20 am ] |
Ok thanks heaps I am going to get an viscous fan on the weekend I will do that along with my el alternator |
| Author: | sideways [ Tue Oct 11, 2011 12:04 pm ] |
steak_knife wrote: I propose Mr G build's a car that's not ugly!!!
Says the guy who owns Buttercup? Piggles looks awesome! |
| Author: | steak_knife [ Wed Oct 12, 2011 5:31 am ] |
sideways wrote: steak_knife wrote: I propose Mr G build's a car that's not ugly!!! Says the guy who owns Buttercup? Piggles looks awesome! |
| Author: | Bennyzarb [ Fri Oct 14, 2011 12:02 pm ] |
I went to the wreackers today and picked up a Jimmy engine fan it is a viscous fan that has seven blades and is just smaller than the vitara one by mm and fits strait on with no cutting of the shroud looks Really good and goes good |
| Author: | Bennyzarb [ Fri Oct 14, 2011 12:03 pm ] |
It is off the older jimneys not the newest one |
| Author: | steak_knife [ Fri Oct 14, 2011 7:01 pm ] |
Al tho the vit hub last's longer, but the difference will be very noticeable...
