| Author |
Message |
ellis
Joined: Wed Sep 08, 2010 8:28 am Posts: 445 Location: GYMPIE QLD
 Posted: Wed Oct 12, 2011 5:01 am |
im trying to get the diff centre out but where u unbolt the brakes i seem to strip them like i did on the last sierra and this 1 they are stiff aswell any ideas on this i was thinking about getting a open ring spanner and cuuting a slit in to it and slidding it on
a quick reply would be good couse i want to get all this done nice and quick to get it back on the road
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Wed Oct 12, 2011 5:02 am |
ellis wrote: im trying to get the diff centre out but where u unbolt the brakes i seem to strip them like i did on the last sierra and this 1 they are stiff aswell any ideas on this i was thinking about getting a open ring spanner and cuuting a slit in to it and slidding it on
That's what brake line spanners are pretty much...
_________________ Lil Foot!
http://tiny.cc/gtsw1
reeceh
Joined: Thu Apr 29, 2010 8:45 am Posts: 1230 Location: Brisbane
 Posted: Wed Oct 12, 2011 5:04 am |
I'm guessing the brake line. Use a pair of quality vice grips
also76
Joined: Tue Aug 02, 2011 11:53 am Posts: 141 Location: Perth
yeah get yourself a set of pipe spanners.
welding the rear will drive like shit on road. why not just spend a bit of money for spartan lockers or sumthin ? much better and less wearing on the diff
ellis
 Posted: Wed Oct 12, 2011 5:05 am |
i just google brake line spanners and yer i might go make 1 i didnt even know they made them
thanks
_________________ if u drive a loud toyota ute u drink rum
ellis
 Posted: Wed Oct 12, 2011 5:08 am |
yes i was thinking about that but every1 says that welding is a bit safer couse its more predictable and yer my last auto in the rear wasnt to bad but yer i dont have much money atm
ellis
 Posted: Wed Oct 12, 2011 5:09 am |
and thanks fot the quick replys
FullyZooked
Joined: Mon Oct 25, 2010 9:01 am Posts: 1009 Location: Bendigo
 Posted: Wed Oct 12, 2011 7:33 am |
Why not stop being a cheap ass and buy a minispool?
$80 and fully reversible?
_________________ Built Suzuki's shall reign Victorious.
ellis
 Posted: Wed Oct 12, 2011 7:57 am |
you could go back to open could'nt you if you got rid of the old spider gears and put other 1's in could'nt you?
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
Vehicle: 03 Jimny
 Posted: Wed Oct 12, 2011 8:08 am |
The four spider gears gets welded up to reverse you'll need to replace all gears or chuck in a new center into the housing
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed Oct 12, 2011 8:15 am |
depends on how it was welded.
_________________ mlm
ellis
 Posted: Wed Oct 12, 2011 8:30 am |
k
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Wed Oct 12, 2011 9:43 am |
FullyZooked wrote: Why not stop being a cheap ass and buy a minispool?
best mod i ever did. highly recommend it. i assume welded rear would be fine, but i dont know how to weld.
FullyZooked
 Posted: Wed Oct 12, 2011 9:53 am |
I've seen some NASTY weld jobs to lock diffs. Spider gears welded to each other, spider gears welded to pins and spider gears not even visible from a pile of shit welded to everything!
No offense to you ofcourse but for the time and effort put in welding and trying not to fuck it you can pay $80 for a slipin mini spool. Remove spider gears and store for when you get sick of paying for tyres.
This also is my best mod so far. Offroad ability has doubled, if not more. Rutted hill climbs no longer leave me frustrated and winching!
whincup
 Posted: Wed Oct 12, 2011 10:38 am |
only problem, which as people say, i often find that i get way further than i should before i think "f**k wrong line!"... doesnt happen much anymore, but at first it did!
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Wed Oct 12, 2011 9:53 pm |
FullyZooked wrote: I've seen some NASTY weld jobs to lock diffs. Spider gears welded to each other, spider gears welded to pins and spider gears not even visible from a pile of shit welded to everything!
Who sells $80 minispools ??
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Wed Oct 12, 2011 11:22 pm |
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Thu Oct 13, 2011 12:06 am |
Low range use to have them for around $80 but there over a $100 now.
_________________ Watch out or you'll get sued.
jonno_racing
 Posted: Thu Oct 13, 2011 12:31 am |
BlueSuzy
 Posted: Thu Oct 13, 2011 1:16 am |
like 160 is going to break the budget..
Brakelines: use a good quality open end spanner, or pipe spanner or vicegrips if fooked already..
I usually hit the spanner quick to undo, And do it up slow by hand.
JrZook
 Posted: Thu Oct 13, 2011 1:31 am |
ellis wrote: yes i was thinking about that but every1 says that welding is a bit safer couse its more predictable and yer my last auto in the rear wasnt to bad but yer i dont have much money atm
I kinda don't understand this modding on the cheap bit. So you can't afford a few hungey 4 a reversible locker setup but you will be able to afford a new center for the diff if it all goes pare shaped and the coin for the extra wear on your treads?
TryHard
Joined: Thu May 13, 2010 1:49 am Posts: 1041 Location: Perth
 Posted: Thu Oct 13, 2011 2:16 am |
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Thu Oct 13, 2011 2:56 am |
JrZook wrote: ellis wrote: yes i was thinking about that but every1 says that welding is a bit safer couse its more predictable and yer my last auto in the rear wasnt to bad but yer i dont have much money atm I kinda don't understand this modding on the cheap bit. So you can't afford a few hungey 4 a reversible locker setup but you will be able to afford a new center for the diff if it all goes pare shaped and the coin for the extra wear on your treads?
It's a chance thing. Welding a diff costs pratically nothing and there's a fair chance it'l work.
A second hand centre is cheaper than an autolocker or minispool too.
The tyre wear effect (as will every other effect, if it's welded properly) will be the same as a minispool.
jimbo_jones
Joined: Sat Jul 19, 2008 11:30 pm Posts: 4361 Location: gong
 Posted: Thu Oct 13, 2011 7:08 am |
missmyljdaze
Joined: Tue Jul 05, 2011 7:16 am Posts: 2323 Location: perth
 Posted: Thu Oct 13, 2011 9:21 am |
a while back there was a lot of talk about the chinese lockers- any progress reports yet?
