It is currently Fri Oct 02, 2026 12:48 am
Post new topic Reply to topic  [ 215 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
Post Posted: Wed Oct 12, 2011 9:34 pm
Hey everyone,
Ive been having dramas with my Jim, I had to be towed it was that bad.
Basically, ive lost all power, when it first started it wasnt that bad, but its practically lost all power now. seems to idle ok (sometimes).
Ive replaced the crank angle sensor, and removed the o2 sensor to find out if the cat was blocked. still runs like a dog.
Ive uploaded a youtube vid of whats going on, this is with the o2 sensor out, so the exhaust is kind loud.
[flash width=480 height=385]http://www.youtube-nocookie.com/v/MCFkhOqLkz0.swf[/flash]
http://www.youtube.com/watch?v=MCFkhOqLkz0
any help you guys have would be awesome, im at the end of my rope almost.
MY BUILD THREAD HERE!!!!!
Vehicle: Jimny!
Post Posted: Wed Oct 12, 2011 9:46 pm
How long has it been running with lost power? Have you washed the engine or driven through water recently?
My corolla did pretty much what you're describing after i got water in the electrics, I COULD NOT find what was wet, and eventually it went away by itself after a week or so.
Vehicle: Suzuki Jimny 2010
Link to the vid for us ifail losers ;)
Post Posted: Wed Oct 12, 2011 9:50 pm
Put the link in the OP for you mate,
As for the water, i was driving back from cape york when it happened. so yeah, plenty of water.... but its been sitting there for several weeks now.
I drove over a tonne of corrugations also, so something coulda shook up a bit i guess.
Vehicle: Yellow Ute
So it has slowly been getting worse and worse?
Maybe check your fuel filter hasn't become blocked up with crap.
Post Posted: Wed Oct 12, 2011 9:55 pm
checked that, had to do it on the side of the road in the outback.... fun.
definatley not blocked. its only a pissy little strainer really anyway
Post Posted: Wed Oct 12, 2011 9:57 pm
Got an engine light on the dash?
Post Posted: Wed Oct 12, 2011 9:59 pm
nope nil light
Post Posted: Wed Oct 12, 2011 10:01 pm
Hmmmm Sounds like its being starved of fuel to me? Or a spark problem...
Vehicle: 03 Jimny
Post Posted: Wed Oct 12, 2011 10:06 pm
Check all you airflow system
Post Posted: Wed Oct 12, 2011 10:16 pm
have a look at the hard lines running along the chassis rail as it could have been damaged by a flying rock/stone.
Post Posted: Wed Oct 12, 2011 10:23 pm
arent the hardlines just brakes? oh yeah fuel..... duh
Post Posted: Wed Oct 12, 2011 10:46 pm
Blowing any smoke when you rev it?
Post Posted: Wed Oct 12, 2011 10:51 pm
is this like che's sierra where the catalytic converter shook loose and clogged up?
Post Posted: Wed Oct 12, 2011 11:14 pm
take your fuel return line off feed it from the engine in2 a bucket, start it.. then try to rev it.. watch what happens... $1 on fuel pump or lines.. it looks to be starving of fuel.
Post Posted: Wed Oct 12, 2011 11:22 pm
I cant watch it too many times at work but lean will likely backfire
I reckon zooky08 and alien are on it, I would pull the intake off at the throttle body (do they have a MAF sensor furhter up?) and try that and it no good pull the exhaust off at the manifold and try again
Post Posted: Wed Oct 12, 2011 11:30 pm
Think they run MAP royce.
More info, how much water did you go through? What were the initial symptoms? Lost power but still running smooth ie no backfiring etc?
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Oct 12, 2011 11:36 pm
thanks for your responses guys,
No smoke is being blown when i rev.
The water i went through was every water crossing between here and the tip of cape york. (up over bonnet on some occasions.) The problem didnt show up till well after the crossings (days after)
I suspect the corrugations may have been a more likely culprit.
yeah ill try taking the intake off and the exhaust at the manifold and ill do another vid shortly.
Vehicle: 4wd
Post Posted: Wed Oct 12, 2011 11:39 pm
Have you tried taking the air filter out?
Watch out or you'll get sued.
Post Posted: Wed Oct 12, 2011 11:50 pm
i had a snorkel sock fitted for the trip, so the aircleaner is pretty schmick still. but yes, i removed the lid and it still did it.
Post Posted: Wed Oct 12, 2011 11:58 pm
has the filter oil from the sock gummed up the MAP sensor?
Post Posted: Thu Oct 13, 2011 12:12 am
which one is the map sensor?
EDIT: got it out, seems fine to me.
EDIT2: just had a closer look, its a mitsubishi item????
can anyone confirm this is correct?
Post Posted: Thu Oct 13, 2011 12:48 am
If its MAP, it wont have a hot wire to gum up like an MAF.
Also take the top covers off and check to see it any water went down the coil plug towers etc.
Not water in the fuel tank?
Lil Foot!
Post Posted: Thu Oct 13, 2011 1:06 am
no water in plug area, pretty sure no water in the fuel. might chuck some metho in there to make sure
Post Posted: Thu Oct 13, 2011 1:23 am
Mitsubishi electrics should be a stock item
Lil Foot!
Post Posted: Thu Oct 13, 2011 1:25 am
To see if its running lean you can take the vac line off the fuel reg. This will increase the pressure in your fuel line and thus increase the fueling
Lil Foot!
Post Posted: Thu Oct 13, 2011 2:56 am
ok, ive dropped the exhaust off at the manifold, cleaned the PCV, cleaned the MAP sensor, and disconnected the airbox.
still does it. so i can rule out the cat.
I did notice the map sensor was not exactly sitting right in its mounting hole. and there was a slight cracking on its plastic casing.
is there a way to test a map sensor? and would a broken one produce these symptoms?
oh i disconnected the vac on the fuel pressure reg, no difference. so i put it back on.
Post Posted: Thu Oct 13, 2011 3:50 am
I'd presume you've checked the spark plugs and water in the oil?
Post Posted: Thu Oct 13, 2011 4:04 am
sure have mate,
havent since i got back from the cape, but it was sparking fine when i checked on side of the road
Post Posted: Thu Oct 13, 2011 4:34 am
it's not just shitty cape yorke fuel?
Users browsing this forum: Google [Bot] and 163 guests
