http://auszookers.com/forum/
Stock body mounts
http://auszookers.com/forum/viewtopic.php?f=5&t=26709
Author:  sogone [ Thu Oct 13, 2011 2:52 am ]
Post subject:  Stock body mounts
Is this required for stock body mounting? Both zooks I have have body lifts. Trying to figure out how to make it back to stock.
Author:  tonyevans [ Thu Oct 13, 2011 3:12 am ]
Post subject:  Re: Stock body mounts
That looks like one of the four that fit under the chassis out-rigger - 2 just behind the front wheel arch and 2 just in front of the rear wheel arch.
Hope this helps and makes sense
Author:  sogone [ Thu Oct 13, 2011 3:32 am ]
My wt has 4 that I can find but 6 of those sunk moon things that are on the outriggers. Can anyone elaborate on how it goes?
Author:  just_cruizin [ Thu Oct 13, 2011 5:27 am ]
All 1.3's have 6 of those. 2 under the front floor and 4 across under the front seats, 2 outside the chassis and 2 inside near the tunnel. The go under the chassis and yes the are required, you will need crush tubes that go up through both the upper and lower rubbers, about 40mm long.
Author:  sogone [ Thu Oct 13, 2011 9:07 am ]
How much is your stock kit? Assuming you make one :D
Author:  Bruce [ Thu Oct 13, 2011 9:13 am ]
Greg should have them in stock. He may not reply for a day or so as he's away on business.
Author:  sogone [ Thu Oct 13, 2011 9:43 am ]
Gay. Need one airbagged ASAP
Author:  just_cruizin [ Fri Oct 14, 2011 1:29 am ]
I have those rubbers available but you'll need to source the sleeves. The rubbers should be maintained with the bodylift as the body shouldn't be hard mounted
