It is currently Fri Oct 02, 2026 5:36 am
Post Posted: Thu Oct 13, 2011 6:35 am
I'm trying to replace my tie rod ends aswell as fix some toe in on my vitara the thing is the tie rod end I've managed to loosen the bolt but it won't budge. The second problem is the bolts to fix toe in/out I managed to loosen the bolt closest to the tie rod end but the next bolt is stuck on pretty well. Tried wd40 soaked it for a night, tried a bug hammer and spanner tried bigger hammer any ideas?
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Thu Oct 13, 2011 7:00 am
Rost off Ice???
Stocker
Post Posted: Thu Oct 13, 2011 8:06 am
stocker wrote:
Rost off Ice???
+1. Next try some heat.
Post Posted: Thu Oct 13, 2011 8:29 am
left & right hand threads on the adjusters.
ball joint separator or 2 hammers should pop the tapered section from the drag link/kunckle.
Post Posted: Thu Oct 13, 2011 12:28 pm
you need to tighten the tie-rod before you can loosen it, seems to work for me.
Post Posted: Thu Oct 13, 2011 4:40 pm
I've tried everything now haha tried heat cold might just cut the bolt off if I can't get it off tomorrow morning with one last try.
Users browsing this forum: No registered users and 128 guests
