It is currently Fri Oct 02, 2026 4:52 am
Post Posted: Thu Oct 13, 2011 8:50 am
hi mates. just wondering what i should do so my car goes through water better? when i first got it it was starting to misfire going through really shallow water. what do you guys do to yours to make it better?
im not going to go deep but just wanna stop it cutting out driving along shallow stuff and it spraying up along trails and stuff
its a 1.3sierra
Post Posted: Thu Oct 13, 2011 9:04 am
Go buy an industrial grade silicone. Silicone the shit out of both ends of the spark plug leads. All around where they join on the dizzy cap. Pull the dizzy cap off and wipe a good bead around the seal. I did this with a snorkel and was driving through bonnet deep water without stalling or misfiring. However when I wrecked the engine to sell, the silicone was that strong it tore the top of the spark plug off. So make sure there good plugs and leads before you do it so you won't have to replace them for awhile.
Post Posted: Thu Oct 13, 2011 9:10 am
do the coil also?
Vehicle: 02 jimny
Post Posted: Thu Oct 13, 2011 10:49 am
Vaseline. helps to keep some in the glove box as a temporary solution
LIVING LIFE ON THE EDGE, TILL YA ROLL
Post Posted: Thu Oct 13, 2011 6:27 pm
If your a coily owner have the Vaseline!
Post Posted: Thu Oct 13, 2011 6:28 pm
And yes do the coil
Vehicle: SJ80, SE416
Post Posted: Thu Oct 13, 2011 8:33 pm
A Sierra can ford water up to around headlight level, and you 'should' be able to hose off the engine with it running (not that you should really do either).
I'd be looking closely at the seal on the dizzy cap and the condition of your leads.
Post Posted: Thu Oct 13, 2011 9:28 pm
most dizzies have a removabvle plug on the cap, fitting a breather to that helps a lot. It is most likely faulty leads, runs ok till get wet, then shorts out.
Post Posted: Thu Oct 13, 2011 9:29 pm
PS I use a spray bottle of water, to find where problem lies.
Users browsing this forum: No registered users and 142 guests
