It is currently Fri Oct 02, 2026 4:52 am
Post Posted: Thu Oct 13, 2011 10:45 am
Hi Guys,
About to do the g16 swap into my sierra, I'm currently running factory air con and just want to know if I'm wrong to assume that the compressor will bolt up to the 1.6??
 Profile WWW ICQ YIM
Post Posted: Thu Oct 13, 2011 11:03 am
Is your g13b multiv?
Is your g16b multiv?
It may boltup, but the pulleys may differ! On mine im going to run a jimny compressor(multiv) with adaptor hoses to the sierra firewall/ac box..
Vehicle: Zookless
Post Posted: Thu Oct 13, 2011 12:17 pm
Yes your AC pump bracket will bolt directly to the G16B.
But as BlueSuzy says, they pulleys are different. Sierra AC has a V pulley, G16B block has a ribbed pulley. You'll need to change the AC pulley to suit.
Post Posted: Thu Oct 13, 2011 7:30 pm
really? mine didn't and it didn't by a lot.
i would tell ya what i did to my aircon when i did the g16 conversion however you are a fuckwit so i wont :wink:
Vehicle: Zookless
Post Posted: Thu Oct 13, 2011 7:43 pm
Here's the Sierra AC bracket bolted directly onto the G16B. (bracket in front of oil filter)
err, ok. Thanks :roll:
Post Posted: Thu Oct 13, 2011 8:03 pm
my sierra bracket had 3 mounting points,one on the front of the motor and 2 on the side, the top side mount was out by about 25mm. if ya
dont think matfan is a fuckwit then ya should check out his old posts.
Post Posted: Thu Oct 13, 2011 9:13 pm
Cheers guys, well hopefully it'll go on easily, if not I guess I'll have to make some sort of adapter out of matchsticks and clag glue.
Oh and I second sheps comment, I just had a bit of a read through some of my old posts.... I really am a fuckwit!
 Profile WWW ICQ YIM
Post Posted: Thu Oct 13, 2011 9:18 pm
Come to think of it, the clutch on the a/c compressor is a little bit dodge at the moment, I wonder if I could replace the whole clutch/pulley assembly with a multiV......
 Profile WWW ICQ YIM
Vehicle: Zookless
Post Posted: Thu Oct 13, 2011 11:07 pm
Ahh, I see...
Shep, didn't you have a different compressor though? Maybe a different bracket as well?
My bracket also has three holes, they all lined up perfectly.
Mat, one of these might work.
Post Posted: Thu Oct 13, 2011 11:16 pm
Cheers for that, I guess I can save my matchsticks and clag glue for the exo build!
 Profile WWW ICQ YIM
Users browsing this forum: No registered users and 142 guests
