It is currently Thu Sep 24, 2026 3:29 pm
Vehicle: Lwb Sierra
Post Posted: Thu Oct 13, 2011 11:13 pm
Hey all, having a bit of a brain dead moment and cant think :crazy: i forgot how to wire up a reverse light on a 3 way switch (rev/off/on) any help would be great
Vehicle: Lwb Sierra
Post Posted: Thu Oct 13, 2011 11:20 pm
haha yea, on my mates car, might put in a 3 way switch on the inside and one at the reverse light so i can switch it off on him whenever i jump in the car :D
Vehicle: Lwb Sierra
Post Posted: Thu Oct 13, 2011 11:45 pm
i think i figured it out :)
Post Posted: Fri Oct 14, 2011 12:01 am
switch pole
1 earth
2 to light earth
3 splice off reverse switch
and the light will have the earth to the switch and positive to power through a fuse
Go hard,
Post Posted: Fri Oct 14, 2011 12:14 am
get a cheap HID kit off ebay too its stupid bright and draw heaps less.
only downside is the warm up time. so maybe even LED
Post Posted: Fri Oct 14, 2011 12:34 am
for the switch part
you need at least a single pole dual throw switch, it will have 3 terminals on it
the middle terminal will be power to the light if its LED or the relay if its higher wattage
one outer terminal tap into the factory reverse light wiring, so it will have power when ignition is on and in reverse and switched that way
The other outer terminal hook up to either a constant power source (fused) if you want to be able to turn it on at any time or ignition for only when the ignition is on or whatever
its very important that if you are using a high wattage light that this switch only feeds a relay (to pin 86, then pin 85 is earthed) otherwise youll melt the reverse switch and or your toggle switch
Post Posted: Fri Oct 14, 2011 5:13 am
for the switch part
Ummm, if you read the question actually he need a three way switch, or a double throw and straight on/off... But what you said plus leave one of the three way options open.
Post Posted: Fri Oct 14, 2011 5:21 am
harvs wrote:
for the switch part
ummm ive read the question and the same question 700 times before, if he is smart enough to wire it up he is smart enough to know his double throw single pole switch is going to need to be a version with an off position :roll:
Post Posted: Fri Oct 14, 2011 8:55 am
Yeah but if you walk into somewhere like Jaycar and ask for a SPDT switch your not going to get one with an off position. Typically that'll come as a SPTT.
Vehicle: Lwb Sierra
Post Posted: Sat Oct 15, 2011 9:09 pm
Hey guys thanks for all your inputs. The switches I found had acc/pwr/acc, would that work? i tested it with a test light and found that it wouldnt, am i doing something wrong?
Ive just wired it to an on/off switch for the time being.
Thanks again
Post Posted: Sun Oct 16, 2011 12:34 am
Doesn't sound like it. Get one of these:
http://www.jaycar.com.au/productView.as ... ATID=978#1
Obviously jaycar sell them, also supercheap have one thats single pole but otherwise the same (you only need a single pole, but the double pole is fine to.)
Then just wire it up how royce said.
Users browsing this forum: Google [Bot] and 113 guests
