It is currently Wed Sep 23, 2026 1:43 pm
Post Posted: Sat Oct 15, 2011 10:31 am
Ive got 30"9.5 maxis buckshots on my coily just wondering what pressure you guys run on the black stuff?
Post Posted: Sat Oct 15, 2011 10:33 am
22-24 psi
Post Posted: Sat Oct 15, 2011 10:37 am
Is that it ? I just got them fitted and haven't checked what the put in the .
I would have put 30+psi in them if I hadn't of asked
Post Posted: Sat Oct 15, 2011 10:38 am
25 psi front and 30 psi rear cos of the locker.
Post Posted: Sat Oct 15, 2011 10:55 am
I go higher when tyres are newly fitted, makes sure they seated in well, less chance of rolling off rim off road..then go down to right pressure after a week or so.
Thats my theory, could be rubbish, but works for me :)
With 31's on 7"rims my Vit is usually at 24 - 26psi on road
Post Posted: Sat Oct 15, 2011 10:57 am
Thanks boys
Post Posted: Sat Oct 15, 2011 12:00 pm
i run my 31s at 26psi front and 22 rear...
lots of USA folks run theirs super low at first to "soften" them up... sounds dangerous to me, lol
just let them down till you get a good contact patch on the road (can test with talcom powder or water on the driveway). then go for a highway run and when you get home the pressure should have gone up around 4psi (give or take a bit). if its up more then you're too low.
Vehicle: Yellow Ute
Post Posted: Sat Oct 15, 2011 7:34 pm
Why do you guys run them that low?
Post Posted: Sat Oct 15, 2011 7:40 pm
You dont need any more when the car only weighs 1000kgs. That's also what the tyre placard says
Post Posted: Sat Oct 15, 2011 7:48 pm
At maximum pressure a single 4wd style tyre is usually rated to carry a load equal to or higher than the whole car, so to make them work with 25% of the load they are required to support you need to lower the pressure
Post Posted: Sat Oct 15, 2011 7:49 pm
saves money at the chiropractor! :P
255 characters
Post Posted: Sun Oct 16, 2011 12:18 am
+1 - the 4 psi rule works a treat in my opinion.
Users browsing this forum: Google [Bot] and 170 guests
