It is currently Wed Sep 23, 2026 2:32 pm
Vehicle: 89 swb vit
Post Posted: Sat Oct 15, 2011 10:41 am
Hey guys pulling a 16b out of a 94 Vitara and putting it in a 89 (previous 16a) vehicle... Got all the engine bay disconnected or seperated but can anyone tell me where and how to remove the ecu and harness etc. I assume it is under the dash but does it require dash removal and how much of the cable harness etc.
Thanks in advance
Post Posted: Sat Oct 15, 2011 11:43 am
Denso or Mitsubishi???
Vehicle: 89 swb vit
Post Posted: Sat Oct 15, 2011 11:50 am
Not even gone looking for it yet so not sure the brand is there a difference to the wiring, location and removal?
Post Posted: Sat Oct 15, 2011 11:55 am
Yep, there's a difference short to long wheel base to...
To get the harness out in one bit you will need to remove the dash, If I was doing the job I'd be doing whole harness, as the ecu has it's finger in running thing's the carb had lil box's for...
IMO....
Vehicle: 89 swb vit
Post Posted: Sat Oct 15, 2011 12:09 pm
Ok dash out it is it was going to be put into the shortie anyway just got to do it a little earlier. What was the difference in the ecu and why did they differ from SWB to LWB Doesnt make sense
Vehicle: 89 swb vit
Post Posted: Sat Oct 15, 2011 11:00 pm
Any info guys Did they actaully differ with the ecu's between swb and lwb?? :?
Post Posted: Sat Oct 15, 2011 11:25 pm
swb and lwb started getting efi engines at different years and there are different efi types and each time they altered the designs for packaging reasons and so on
easiest way is to swap the whole dash and complete wiring loom over, then its all jsut unplugging and plugging back in, you arent trying to graft anything
Vehicle: 89 swb vit
Post Posted: Sat Oct 15, 2011 11:35 pm
Royce
Thanks for the reply... Yep your right i am striping a carby vit and giving it a transplant. I have a donor car with engine and all electricals so will move what i need to move. Is there anything in particular i need to watch for with the move. Previous reply reffering to difference between SWB and LWB had me worried.
P.S already got the Fuel tank covered
Post Posted: Sat Oct 15, 2011 11:40 pm
lwb will be different for things like the rear doors, the way the power windows (if fitted) are wired and little stuff like that
but you should be able to work around all that easy enough
Watch out for everything :) mark every plug and socket twice, once with where it goes and once with a number that will correspond with the same number on wherever it goes, dont ever assume youll remember anything, write it all down
Post Posted: Sat Oct 15, 2011 11:55 pm
I hate to admit when Royce is right but I have to back him up on this one!
Users browsing this forum: No registered users and 183 guests
