| RedArc Soleniod HELP! http://auszookers.com/forum/viewtopic.php?f=5&t=26786 |
| Author: | ridzilla [ Sat Oct 15, 2011 12:16 pm ] |
| Post subject: | RedArc Soleniod HELP! |
I've finally gotten around to installing my redarc dual battery system and I'm not sure if it is actually working xD Any pointers for testing? |
| Author: | sbbunno [ Sat Oct 15, 2011 12:56 pm ] |
| Post subject: | Re: RedArc Soleniod HELP! |
If it's glowing red it should be working, when the light is off it means the main battery is below 12.8 Run the car when the main hits 13v it should light up |
| Author: | Lockie666 [ Sat Oct 15, 2011 1:05 pm ] |
The touch the blue wire to 12+ feed and you will manually click over, when the redarc is red it means it's running both batteries |
| Author: | remydog05 [ Sun Oct 16, 2011 1:28 am ] |
You should find everything on here http://redarc.com.au/home |
| Author: | ridzilla [ Sun Oct 16, 2011 7:48 am ] |
Cheers guys! Guess it IS working But I managed to strip the override cable all the way back into the box :/ I was only doing it the normal way I do it but oh well, I now have a completely exposed wire... Any suggestions on how to insulate it? |
| Author: | skyman [ Sun Oct 16, 2011 8:26 am ] |
High quality Heat shrink wire wrap maybe? |
| Author: | ridzilla [ Sun Oct 16, 2011 10:06 am ] |
skyman wrote: High quality Heat shrink wire wrap maybe?
Yeah, I just don't want to heat the soleniod to much and wreck it |
| Author: | skyman [ Sun Oct 16, 2011 11:59 am ] |
Ahhh, this type of shrink wrap you could shrink with a lighter, the woman's hair dryer, or a match..no need to get too hot. |
| Author: | MacDaddy [ Sun Oct 16, 2011 12:10 pm ] |
Just in case you dont know where to get heat shrink from, most electrical hobby shops have it, like Dick Smiths etc... |
| Author: | Shansh [ Sun Oct 16, 2011 7:41 pm ] |
go to the electrical wholesaler and get some, hair dryer flat out will work, will just take a little longer, much safer near your solenoid rather than a heat gun |
| Author: | ridzilla [ Mon Oct 17, 2011 10:41 am ] |
Cheers boys Guess I'll be going shopping xD |
