| Tips on removing starter motor http://auszookers.com/forum/viewtopic.php?f=5&t=26841 |
| Author: | buzbox [ Mon Oct 17, 2011 7:56 am ] |
| Post subject: | Tips on removing starter motor |
I know that all I have to do is disconnect the battery, remove the cables to the starter and take out two bolts to remove. But in the Vit the top bolt is in a prick of a spot. Any tips on getting it out? Is it a matter of using a stubby spanner, patience and swearing? or is there an easier way? |
| Author: | steak_knife [ Mon Oct 17, 2011 8:46 am ] |
| Post subject: | Re: Tips on removing starter motor |
Take the intake support bracket off, heap's of room then... That & ratchet spanner's.... |
| Author: | buzbox [ Mon Oct 17, 2011 8:51 am ] |
I've got ratchet spanners, but they mght be a bit long. |
| Author: | alien [ Mon Oct 17, 2011 8:54 am ] |
in a sierra its way easier if you take the airbox out first, gives a lot more room to get in there. Not sure about a vit though? |
| Author: | larry [ Mon Oct 17, 2011 9:08 am ] |
take the top bolt out first. i used a socket, swivel section, 2 extensions and ratchet, its still a bitch |
| Author: | RIKSTR [ Mon Oct 17, 2011 9:16 am ] |
X2 |
| Author: | Jester [ Mon Oct 17, 2011 10:24 am ] |
get a body lift piss easy then |
| Author: | royce [ Mon Oct 17, 2011 10:27 am ] |
go rock climbing for a few years, the bolt gripping and twisting strength you get in your fingers is worth more than any amount of funny shaped spanners |
| Author: | buzbox [ Tue Oct 18, 2011 5:42 am ] |
Jester wrote: get a body lift piss easy then Already do royce wrote: go rock climbing for a few years, the bolt gripping and twisting strength you get in your fingers is worth more than any amount of funny shaped spanners
yeah true but nah |
| Author: | atari4x4 [ Tue Oct 18, 2011 5:49 am ] |
go go gadget ratchet fingers. |
| Author: | Ruthless [ Tue Oct 18, 2011 6:13 am ] |
get a bigger hammer and belt it till it breaks the casting |
| Author: | buzbox [ Tue Oct 18, 2011 6:28 am ] |
I've actually taken an easier way out. Clutch started it and dropped it off at the auto elecy. He didn't charge me too much last time but I think he hates my car I don't have much time in the arvo's and when I do get home I CBF'd and I can't wait until the weekend to work on it. |
| Author: | christover1 [ Tue Oct 18, 2011 6:44 am ] |
Body lift does help, so does the inspection hole I made in inner guard. I fitted my starter about 6 months ago, bugger of a job. But during engine out job, I removed the carbon cannister first, as well as the inlet support, that was way easier. |
