[ 4 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2658 Location: Georgetown, Guyana
 Posted: Tue Oct 18, 2011 12:59 am |
Does any one have (or have access to) an unmolested 2.0 Grand Vitara - a '98 would be preferable, but anything from 98~05 will do (beggars can't be choosers).
I need to know the ride height - measure from the lower edge of the wheel rim please - in a straight line through the wheel center to the arch above - on all four corners (this method eliminates the tire size & pressure as variables).
I've just discovered that none of the shocks are original - I knew the rear ones weren't (they are Monroe Adventure Series), but I've just discovered that the front have also been replaced, and I am now curious as to whether the springs are original or not.
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Tue Oct 18, 2011 4:24 am |
I can measure the next doors V6 auto for you iof thats any help.
_________________ B4T
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Tue Oct 18, 2011 5:45 am |
Ok, just measured a stock 03 GV 2.5L Auto, as per your measurement requirements, 690mm front, and 660mm rear, hope that helps...
fordem
 Posted: Tue Oct 18, 2011 1:30 pm |
Much obliged gentlemen - that is a start - but I really don't know if a 2.0 & a 2.5 GV have the same ride height when they leave the factory.
The parts catalogue shows they both use the same rear spring, but the front springs are different - presumably to cope with the increased weight of the engine & transmission (roughly 200lbs).
I get the following
LF - 667 .... RF - 662
LR - 665 .... RR - 667
One of the things that I noted is that the measurements are pretty close - to with 5mm, so there doesn't seem to be any significant sagging.
Another question - what do your front struts have over the piston rods - the part catalogue shows an accordion style boot, but what's there right now is a "semi-rigid" plastic sleeve - imagine the metal sleeve on a rear shock, and you get the idea, except this is made of plastic, being plastic it does have some flex, but is definitely not intended to accomodate changes in length like the rubber accordion ones do.
[ 4 posts ] |
Users browsing this forum: No registered users and 151 guests
